HIDs - Ford Powerstroke Diesel Forum
post #1 of 21 Old 01-03-2013, 03:07 PM Thread Starter
tunafish25's Avatar
HIDs
I am looking for brighter headlights in my truck and I thought HIDs would work awesome. Anyone install them into their truck? If so what color did you go with? Thanks!
-Matt
2006 F350 6.0 Powerstroke
Crew Cab, FX4
Black
4in Turbo Back Exhaust
Edge Insight CTS
"Si vis pacem, para bellum"
tunafish25 is offline
post #2 of 21 Old 01-03-2013, 04:15 PM
c dog's Avatar
I have them. DDM Tuning 55w hi lo beams. I have tried the 5k, 6k, 8k. I like the 6k the best and there website says its the most popular color. I believe 4k will have the most light out put. The bluer you go you loose light output. I have installed DDM tuning 55watt hi low on my excursion, nissan car, jeep TJ & JK, escalade. I would recomend the extra $$ for the 55 watt and hi lo beams
c dog is offline
post #3 of 21 Old 01-03-2013, 06:01 PM
Chapter Director
psd_va's Avatar
i too have 6k 55w hi/lo's on both my truck and my DD civic. i also have 35w in the fogs on my truck. i will never go back to halogens. they are so bright i almost never use my hi beams. being lifted though i piss A LOT of people off on the roads.
03 F350 6.0 SRW 4X4 lariat
481hp 832tq
8" super lift 385/70r16 Toyo MT's
FatBoy traction bars
Durastroke stg1
intake
MBRP 5" straight pipe
Custom tuned by Vivian "Looney Wild Track"
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
Updated fuel pressure regulator (Blue spring mod)
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
post #4 of 21 Old 01-03-2013, 08:24 PM Thread Starter
tunafish25's Avatar
Any recommendation on where to get them?
Sent from my HTC Vivid using AutoGuide.Com Free App
-Matt
Crew Cab, FX4
Black
Edge Insight CTS
post #5 of 21 Old 01-03-2013, 08:27 PM
Chapter Director
psd_va's Avatar
DDMtuning.com
481hp 832tq
Durastroke stg1
intake
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
post #6 of 21 Old 01-03-2013, 09:09 PM
lowrider284's Avatar
+1 for DDM prices are great
lowrider284 is offline
post #7 of 21 Old 01-04-2013, 07:51 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Another option if beam control is a concern..New True projection hid kits.
CT Performance, Inc. is offline
post #8 of 21 Old 01-04-2013, 08:08 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
I recommend 6000K 55 watt for your fog lights.
I had the same for my headlights, but it proved to be way too bright for my liking or for anyone on the roads liking.
So I removed the headlight HID's and left the ones in the fogs, which is great.
You should also take a look at RetroSolutions for your HID purchase.
They are a supporting vendor of this site and give discounts for powerstroke members!
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #9 of 21 Old 01-04-2013, 08:34 AM
JesseKK's Avatar
Quoted: 33 Post(s)
Garage
So teh 55watt kits arnt too hot for the stock housings ? I hav the 35watt kit in 6k and love it.
JesseKFK
2007 F250 XLT CC 6.0 PowerStroke FX4 R.I.P. 3.6.16
Livewire TS LOoNeY
Studded
BPD 58v FICM
BPD Oil&Egr Cooler
Glow Shift Pyro,Fuel
High Idle Mod UF#4
Fog Light Mod
Harpoon Mod
Dome Override Mod
6000k Bi-neon Hids
Sinister Coolant Filter
8in Rize Ind 4 link
35" Mickeys on 20s
Blue Leds
Power Service Every Fill Up
ATV 2008 Yamaha Raptor 700 FI
KCCO
Originally Posted by Karls03 View Post
I hate Edge power products so much, I quit using Edge shaving gel
JesseKK is offline
post #10 of 21 Old 01-04-2013, 08:36 AM
A lot of guys run the 55w in headlights and 35w in the fogs. I had my HID's before I found this site, but after looking at the box I have 35w in the headlights and I am getting a matching set of 35w fog lights
KCCO
Paul Devereux
2005 FX4 Lariat Dark Shadow Gray
AirRaid Filter, 6 inch Pro Comp Lift. 17 inch Mikey Thompsons with 35 inch Nittos, sinister coolant filter, MBRP 4" straight pipe, 6K HID, Zoodad, SCT with tunes from Vivian (Looney and Looney fuel) and Tony, dashboss with EGT and FP, 08' tail lights, blue spring, lowes CCV mod, 03' turbo
Soon... coolant flush.
DEVERO2 is offline
