| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Headlight mod help
hello all,
I am trying to find a wright up for the hi/lo mod. I would like my low beams to stay on when my hi beams are on. If anyone has any info or a wright up this it would be greatly appreciated. |
I don't about that mod but there is one where you can make the fogs stay on with the highs
The high and low are the same bulb so they are always on?? at least 05-07 are
I have seen the fog light mod. Yes they are the same bulb but they have filaments in them.
its one bulb so what does it matter? i dont think the light output would be much more. get recons with 2 seperate bulbs then you can make them both stay on
Found this on another site with a simple google search
![]() THIS IS NOT MY MOD USE IT AT YOUR OWN RISK Quote:
Anyone have any luck with this mod?
There is a unit called a Bright Box that will do this for you.
Ok Thank you. I did see something about that somewhere.
On your normal high beams, your low part shuts off. With the mod, the lows stay on.. Try this with your factory setup. When dark out, look at low beams. Then pull back and hold the "flash to pass" both lows and highs are on. Now compare with factory high beams. You should see the difference. The "Bright Box" also kept fogs on with high beams. |
