Headlight Troubles - Ford Powerstroke Diesel Forum
Old 12-02-2012, 01:01 PM
Headlight Troubles
Hello everyone. I have an 07, f-250 with headlight issues. The headlights will not always turn on. At first they would turn on after a few minutes of leaving the switch on, now they don't turn on at all. I have checked fuses and bulbs, all good. All other lights turn on and function properly when headlight switch is turned on. If I switch to high beams, those function properly.
Thank you all for your time and knowledge.
Old 12-14-2012, 02:25 PM
UPDATE---
I have since replaced the headlight switch and the multifunction switch and the low beams still won't turn on.
Any input would be greatly appreciated.
Old 12-14-2012, 02:45 PM
It may be a headlight relay. I'd check under hood fuse box and see if there are any relays in there that may have gone bad either the contacts or the coil. I maybe sending you on a wild goose chase but may be worth looking for relays
Last edited by RedneckYankee; 12-14-2012 at 02:48 PM. Reason: Posted before done commenting
Old 12-14-2012, 04:26 PM
Is there a way to test the relay?
Old 12-14-2012, 06:16 PM
If you can determine what two terminals are the coil and what two are the normally open contacts. Apply 12VDC to the coil terminals and check for continuity with a ohm meter. Not for sure if there would be a diagram on the relay or not. If not you should have a resistance reading across two terminals and the other two would be open. Like I said not really even sure that there is a headlight relay but I'm thinking there should be especially with auto on lights.
