06 radio in 05 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 12-01-2012, 04:31 PM Thread Starter
Kyleu890's Avatar
06 radio in 05
Alright this might be a dumb question but I just bought my second superduty and this time I got an 05 an it has the newer radio in it but it doesn't have a factory aux in. I read that ford has 2 different companies making their radios. One company has Aux in and the other doesn't and they are different electronics but have the same face. So all I'm asking is can I swap a 06/ 07 radio with factory aux in for a factory 05 head unit with out an aux in port? Any help would be appreciated! Thanks guys and girls!
Sent from my iPhone using AutoGuide.com App
04 ccsb f350 little red rip! Previous truck
05 ccsb f250 currently bone stock no plans to change it.
Kyleu890 is offline
post #2 of 5 Old 12-01-2012, 08:18 PM
Quoted: 3 Post(s)
I don't know if any reason why it shouldn't work just fine.
The harness should be the same (at least the service manual shows the connector being the same). Pretty sure the wiring is the same through the whole series (go check out the aftermarket wiring harnesses at crutchfield.com or somewhere similar to see what years they fit).
Lee
ve7fet is offline
post #3 of 5 Old 12-02-2012, 08:07 AM Thread Starter
Kyleu890's Avatar
Thanks lee I will check into that!
Kyleu890 is offline
post #4 of 5 Old 12-02-2012, 12:25 PM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Yes it can. It was changed in 04, so the 05-07 trucks share the same unit.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #5 of 5 Old 12-02-2012, 12:31 PM
ZMANN's Avatar
Quoted: 1587 Post(s)
mine has an Aux button but no real input
so I just went with an aftermarket unit
We Miss you Ronnie
ZMANN is online now
