| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Scangauge II PIDs
I'm looking to see if there is a PID to check the glow plugs. I checked out the write up thread on monitoring the 6.0 and I didn't see a PID for glow plugs listed. Is there one and I just didn't see it??
Thanks for the help! |
Here is a list.
Below I have added to the list of Xgauges Fords specs for most of the gauges. KO=KEY ON LI=LOW IDLE HI=HIGH IDLE OR=OPERATING RANGE (High idle for these tests is set at 2500 RPMs, and Engine at operating temps) FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03) TXD: 07E02209CE RXF: 0462450906CE RXD: 3010 MTH: 006401000000 NAM: FVP KO=12.0 LI=14.0 HI=14.0 OR=10.5-15.5 FICM Logic Power (Volts) (Should be 12 volts) TXD: 07E02209CF RXF: 0462450906CF RXD: 3010 MTH: 006401000000 NAM: FLP KO=12.0 LI=13.5 HI=13.5 OR=10.5-15.5 FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced. TXD: 07E02209D0 RXF: 0462450906D0 RXD: 3010 MTH: 006401000000 NAM: FMP KO=47 LI=47.5 HI=47.5 OR=40-52 (yes, that is what it says from Ford) VGT Duty Cycle (%) TXD: 07E022096D RXF: 04620509066D RXD: 3010 MTH: 00647FFF0000 NAM: VGT KO=0 LI=73 HI=43 OR=0-100 % Engine Oil Temp TXD: 07E0221310 RXF: 046245130610 RXD: 3010 MTH: 00090005F05F (00090005FFD8 alternate MTH found) NAM: EOT Engine hot KO=190 LI=190 HI=190 OR= -40 - 302 *F Trans. Fluid Temp TXD: 07E1221674 RXF: 046205160674 RXD: 3010 MTH: 000100080000 NAM: TFT Horsepower TXD: 00 RXF: 400080000000 RXD: 0000 MTH: 000A00240000 NAM: HPR Inj. Control Press. (ICP / HPOP) TXD: 07E0221446 RXF: 046205140646 RXD: 3010 MTH: 003900640000 NAM: ICP KO=0 LI=625.5 HI=1400-1450 OR=0-4045 ICP Voltage (Volts) TXD: 07E02216AD RXF: 0462451606AD RXD: 3010 MTH: 004827100000 NAM: ICV KO=0.2 LI=1.0 HI=1.8 OR=.15-4.7 Volts IPR Duty Cycle TXD: 07E0221434 RXF: 046285140634 RXD: 3008 MTH: 0DCA03E8000A NAM: IPR % KO=14.84 LI=24 HI=40.60 OR=0-50 % Throttle Position 1 (Volts) TXD: 07E0220917 RXF: 046245090617 RXD: 3010 MTH: 006404000000 NAM: TP1 Note: Voltage of the ETC Throttle Position Sensor number 1 KO=4.0 LI=4.0 HI=3.4 OR=0.7 - 4.2 VOLT Accelerator Pedal Track 1 Throttle Position 2 (Volts) TXD: 07E0220918 RXF: 046245090618 RXD: 3010 MTH: 0064040000000 NAM: TP2 Note: Voltage of the ETC Throttle Position Sensor number 2 KO=1.4 LI=1.4 HI=1.9 OR=1.4 - 4.1 VOLT Accelerator Pedal Track 2 ---------------- Throttle Position Desired (Degrees) TXD: 07E022091A RXF: 04624509061A RXD: 3010 MTH: 0064020000000 NAM: TPD Note: ETC Commanded Throttle Angle, in degrees. Throttle Position Actual (Degrees) TXD: 07E022093C RXF: 04624509063C RXD: 3010 MTH: 006402000000 NAM: TPA Note: The measured throttle angle from the throttle sensor inputs. EGR Duty Cycle (Percent) TXD: 07E022166E RXF: 04620516066E RXD: 3010 MTH: 006440000000 NAM: EGR KO=0 LI=0-15 HI=32 OR=0-44 % EGR Throttle Position Control Signal TXD: 07E022096C RXF: 04620509066C RXD: 3010 MTH: 00647FFF0000 NAM: ETP EGR Valve Position (mm) TXD: 07E022096A RXF: 04620509066A RXD: 3010 MTH: 000100010000 NAM: EVP Note: EGR Valve Position in hundredths of a millimeter, where 0 mm indicates a closed EGR valve position. EGR Valve Position Desired (%) TXD: 07E02209D2 RXF: 0462050906D2 RXD: 3010 MTH: 00647FFF0000 NAM: EVD >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> EGR Valve Position Measured (%) TXD: 07E02209FE RXF: 0462050906FE RXD: 3010 MTH: 00647FFF0000 NAM: EVM Note: MEASURED EGR Valve Position, in %, where a low value indicates a closed EGR valve (0 EGR flow), and a high value indicates an open EGR valve. KO=0 LI=0 HI=9.72 OR=0 - 14 PERCENT EGR Valve Position (Volts 0-5) TXD: 07E022167E RXF: 04620516067E RXD: 3010 MTH: 000133330000 NAM: EGV KO=0.8 LI=0.8 -1.0 HI=1.3 OR=0.6 - 3.5 VOLT Camshaft & Crankshaft Sync (1 = in sync, 0 = not in sync) TXD: 07E02209CD RXF: 0462050906CD RXD: 3000 (3001 alternate) MTH: 000100010000 NAM: SYC KO=0 LI=1 HI=1 OR 0-1 (NO/YES) Intake Air Temperature 2 (Fahrenheit) TXD: 07E02216A8 RXF: 0462051606A8 RXD: 3010 MTH: 000100010000 NAM: IA2 Engine HOT KO=113 LI=113 HI=113 OR= -40-250 *F Barometric Pressure TXD: 07E0221127 RXF: 046285110627 RXD: 3008 MTH: 003100500000 NAM: BMP Here is another BAR if the above one is not working for you. The one below works for me. Barometric Pressure (PSI) TXD: 07E0221442 RXF: 046285140642 RXD: 3010 MTH: 001D00500000 NAM: BAR KO=96.5 (14) LI=96.5 (14) HI=96.5 (14) OR=50 - 120 (7.3 - 17.4) kPa (PSI) Exhaust Back Pressure TXD: 07E0221445 RXF: 046285140645 RXD: 3010 MTH: 001D00500000 NAM: EBP KO=103 (15) LI=110 (16) HI=110 (16) OR=55 - 607 (8 -88) kPA (PSI) Fuel Level TXD: 007E02216C1 RXF: 0462451606C1 RXD: 3010 MTH: 000101480000 NAM: FL Volume Fuel Desired TXD: 07E0221411 RXF: 046245140611 RXD: 3010 MTH: 006400100000 NAM: VFD Mass Fuel Desired (Milligrams Per Stroke) TXD: 07E0221412 RXF: 046205140612 RXD: 3010 MTH: 000100100000 NAM: MFD KO=0 LI=7.5 HI=10.7 OR=0-100 Engine Run Time (Minutes) TXD: 07DF011F RXF: 0441051F RXD: 2810 MTH: 0001003C0000 NAM: ERT >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Fan Speed Sensor (RPM) TXD: 07E022099F RXF: 04620509069F RXD: 3010 MTH: 000100040000 NAM: FSS KO=0 LI=533 HI=488 OR=0-4000 Manifold Absolute Pressure (PSI) (BOOST) TXD: 07E0221440 RXF: 046285140640 RXD: 3010 MTH: 012203200000 NAM: PSI MAP is a standard gauge - but this XGauge is actually better than the standard one. It has a larger range which was needed because the standard gauge tops out around 37 psi absolute (about 22 lbs of boost), which diesels have no problem doing. This one should read well beyond 22lbs of boost. With a little tweaking you can adjust this to read boost as you said. To do this, just plug in the MAP code - get a reading from it with the key in the on position but the engine off, then based on the reading changed the last 4 digits of the MTH to whatever corresponds to your reading on this table 12.7 FF81 12.8 FF80 12.9 FF7F 13.0 FF7E 13.1 FF7D 13.2 FF7C 13.3 FF7B 13.4 FF7A 13.5 FF79 13.6 FF78 13.7 FF77 13.8 FF76 13.9 FF75 14.0 -- FF74 14.1 -- FF73 14.2 -- FF72 14.3 -- FF71 14.4 -- FF70 14.5 -- FF6F 14.6 -- FF6E 14.7 -- FF6D 14.8 -- FF6C 14.9 -- FF6B 15.0 -- FF6A So, for example if you got a reading of 14.5 PSI with key on engine off you'd change the MTH to 01220320FF6F and the reading should read 0.0 with key on engine off and would then show how many lbs of boost you were at when the vehicle is running. Injector Timing Before Top Dead Center (Degrees) TXD: 07E02209CC RXF: 0462850906CC RXD: 3010 MTH: 000A00400000 NAM: ITM KO=0 LI=-8.71 HI=+3.5 OR-50 - 50 ANGLE (Degrees) Injector Timing (TDC) Fuel Injector Pulse Width (Microseconds) TXD: 07E0221410 RXF: 046205140610 RXD: 3010 MTH: 000800010000 NAM: FPW Gear (Transmission Gear) TXD: 07E12211B3 RXF: 0462051106B3 RXD: 3008 MTH: 000100020000 NAM: GER Self explained Vehicle Speed Sensor (MPH) TXD: 07E02211C1 RXF: 0462051106C1 RXD: 3010 MTH: 000102000000 NAM: VSS Self explained Accelerator Pedal Position (%) TXD: 07E02209D4 RXF: 0462050906D4 RXD: 3008 MTH: 000100020000 NAM: AP% Key On=0 LI=0 HI=13 Op range=0-17.75 (mine reads up to 99%, not sure why) DTC Count (Diagnostic Trouble Code Count) TXD: 07E0220200 RXF: 046205020600 RXD: 3008 MTH: 000100010000 NAM: DTC Counts trouble code cycles KO=0 LI=0 HI=0 OR=0 - 255 VREF (Calibration Voltage Input) TXD: 07E0221155 RXF: 046245110655 RXD: 3010 MTH: 006433330000 NAM: CVI KO=4.9 LI=4.9 HI=4.9 OR=4.5 - 5.5 VOLTS Reference Voltage Net Torque into Torque Converter (Ft-Lbs) TXD: 07E02209CB RXF: 0462050906CB RXD: 3010 MTH: 000100010000 NAM: TRQ __________________ |
That list was gotten from Sean (Amdriven2liv)
Thanks Eli! That looks like the same list posted in the monitoring thread. I don't see anything about glow plugs in there though...
Then most likely it does not exist...
Cuz Sean is very smart in this scangauge2 codes (taught me alot) and he never talked about it. So, IDK
Bump for myself to find it easier on my phone through auto guides favorites section
There are three PIDs available for glow plugs. GPCTM = Glow Plug Coil On Time (Actual time the coil is hot) GPL = Glow Plug Indicator (Just that the Wait to start light is on or not) GPLTM = Glow Plug Indicator On Time (This would list how long the light was on ) Let me see what I can do on these. Might take a few days, and will need to have a couple people test these on different MY trucks. Thanks for bringing this up. |
Ok, time for some testing!!!
Here are a few new Xgauges to try. These came from James at Linear Logic. Here’s what I’ve come up with for the XGauges requested. MAP Voltage (Volts) TXD: 07E0220900 RXF: 046205090600 RXD: 3010 MTH: 000104000000 NAM: MPV Note: This one seems a bit odd, but try it out and let me know if you need finer resolution. This one will go by whole numbers, but the range is something like +/- 32 Volts which seems weird for a sensor – they’re usually 0-5 volts EP Volts (Volts) TXD: 07E02216AE RXF: 0462451606AE RXD: 3010 MTH: 000100800000 NAM: EPV Note: This one may have weird readings if the values get to high, let me know. Glow Plug Coil Time (Seconds) TXD: 07E0221450 RXF: 046205140650 RXD: 3010 MTH: 000100080000 NAM: GPT Glow Plug Light On TXD: 07E0221667 RXF: 046225160667 RXD: 3201 MTH: 000100010000 NAM: GPL Glow Plug Lamp On Time (Seconds) TXD: 07E0221451 RXF: 046205140651 RXD: 3010 MTH: 000100080000 NAM: GPT Try those out and let me know how they do. Regards, James DeLong Linear Logic LLC Operations Manager |
Just tried the glow plug coil. Didn't work right. Will get an update on this one.
