Grounding HID's - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-02-2012, 10:15 AM Thread Starter
DoubleDpsd's Avatar
Grounding HID's
Hey guys I wanted some opinions on grounding here on the cross member. These pics aren't mine they are from another member I bought the kit from on here. If you can't read the red sentences it says he drilled a hole through the cross member then used a sheet metal screw then covered it with calking to protect from the elements. This is a RetroSolutions 55w 5000k kit. What do you think, or is there another more recommended spot? Thanks.
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #2 of 9 Old 11-02-2012, 12:15 PM Thread Starter
DoubleDpsd's Avatar
bump .
post #3 of 9 Old 11-02-2012, 12:28 PM
SuperCrutyPS's Avatar
Quoted: 305 Post(s)
Garage
I would think the Rad support would work. If not you can always make some holes through it and run your grounds directly to the battery on each side. Just a thought.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
post #4 of 9 Old 11-02-2012, 12:51 PM
retrosolutions's Avatar
Quoted: 43 Post(s)
Any location that is a solid metal spot would work really. Just be sure to sand an area big enough for the ring connector, so that all paint and primer is removed and apply some dielectric grease to that so no corrosion/rust builds up.
Caulking may not be the best of ideas though, since you have to make sure there is no air pockets under it and everything has to be perfectly dry. Even if its humid out, that moisture could get trapped under the caulk and create corrosion in that connection. Hope that gives you some ideas!
Mon.- Fri. 9am-4-pm Eastern time
(860) 406-4443
retrosolutions is offline
post #5 of 9 Old 11-02-2012, 01:25 PM Thread Starter
DoubleDpsd's Avatar
Thanks for the quick input retro I will def consider that.
Sent from my DROIDX using AutoGuide.Com Free App
post #6 of 9 Old 11-02-2012, 01:28 PM
Don't mind me
westcoaststrokin's Avatar
Quoted: 3 Post(s)
Yep make sure your ground is solid!
Josh
04 F350 CC SB DRW IT HAS SOME STUFF
"Idiopathic, from the Latin meaning we're idiots cause we can't figure out what's causing it." House M.D.
westcoaststrokin is offline
post #7 of 9 Old 11-03-2012, 06:19 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
With aftermarket electronics, I would not recommend this.
It should be grounded to chassis ground, not battery ground.
Also, make sure your metal is actually connected to the frame.
I've seen metal that was connected to plastic or composite material which is not grounded at all.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #8 of 9 Old 11-04-2012, 07:04 AM
Quoted: 43 Post(s)
Very true! We have seen it all too often. It may look like a great ground, but it all depends on what it is connected to. Thank you for pointing that out!
(860) 406-4443
post #9 of 9 Old 11-04-2012, 08:39 AM Thread Starter
DoubleDpsd's Avatar
Thanks dfuzz.
