Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Electronics Discussion
Old 10-22-2007, 08:29 PM
led strobe lights install
so i ordered one of those police flashers off the internet with some led lights and last night i hooked it up and turned it on and they arent bright at all when i hook the lights up straight to the battery they are bright as hell but when i hook them up through the flasher they are dim any suggestions
Old 10-22-2007, 08:31 PM
What brand are they?
Old 10-22-2007, 08:32 PM
the flasher is sho-me and i dont remember what the lights are i'll check in the morning
Old 10-22-2007, 08:35 PM
HVAC IN NC
You could probably hook them up to a aftermarket relay and run a toggle switch into the cab that would give you direct power with out over loading the toggle, just a suggestion
Old 10-22-2007, 08:41 PM
i have the upfitter switches would that work
Old 10-22-2007, 08:48 PM
hook them up to a relay after the switch and it will boost the output
Old 10-22-2007, 08:52 PM
HVAC IN NC
Just find a good 12v switch that will handle the amp load and you should be fine, I know i have gotten some thru radioshack that have worked for me in the past wiring up cooling fans on other trucks.
Old 10-25-2007, 04:21 AM
Send a message via AIM to pistolpete837
radioshack should have everything you need to get it right
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.2
