Single vs dual 10 IN sub? - Ford Powerstroke Diesel Forum
Old 10-04-2012, 04:23 PM
I'm having a sub and amp installed In my truck Saturday and am wondering if I would notice the difference between a single or dual 10IN setup. I had a single 10 before and was happy with it but I've always thought bigger is better. Thanks for any advice in advance.
Old 10-04-2012, 06:19 PM
i dont think you will notice much of a difference, and you can get by with a smaller amp. i think 1 well powered sub will perform better than 2 subs that are under powered because of an amp that is too small because you couldnt afford a bigger amp. also it is going to be tough to get a box in a truck that has enough square footage for 2 subs. in high school my car with one 12" sub sounded better than my buddies with two 15" subs because i think his was under powered. i had a 250w amp and he had a 400w amp.
Old 10-05-2012, 08:22 PM
A single ported shallow 12" works great in the 04-07 Super Duty.
Old 10-07-2012, 08:09 PM
2- pioneer IB Flat 12" more than enough room in the CC trucks
Old 10-08-2012, 08:34 AM
Now that is quite the box!
Old 10-08-2012, 11:10 PM
If you can afford the space dual is the way to go. I run a pair of Alpine type X ported with 1000w ea. The enclosure design is one of the biggest factors. My home audio setup uses a pair of M&K MX350 which each have two 12" drivers on a push pull system with just 350w ea but they will out do most higher powered systems I have heard. Granted many cheeper systems use peak power rather than RMS.
Old 10-18-2012, 07:25 PM
If you have the correct box and power to push 2 woofer, go with 2
1 10 inch woofer moves 10 inches of cone air ,2 is 20 inches of cone air space
last week i help a friend replace one 12 and installed 2 10 inch woofer sounds better and louder with the same amplifier
Old 10-18-2012, 07:37 PM
Yeah it's a Turbo Diesel
Feedback Score: 8 reviews
My shallow mount 12" single kicker with proper built box and studded with poly sounds better than two 10's
Sent from iPhone
Old 10-19-2012, 03:23 AM
box built... pioneer IB Flat 12's Polk audio 5-Channel
Old 10-19-2012, 03:25 AM
custom pods for tweets..... and a pioneer DD to run it all
