T-Tap or Posi Tap - Ford Powerstroke Diesel Forum
Old 10-03-2012, 07:54 AM
T-Tap or Posi Tap
Hey guys I had a friend turn me on to these and am now going to use them on all electrical connections....thought I would pass it on.
Posi-Lock(R) - The Best Connectors You'll Ever Use!
Old 10-10-2012, 08:36 AM
Very cool! Thanks for sharing.
Old 10-14-2012, 09:32 AM
Suck, Squish, Bang, Blow!
All electrical connections should be soldered... Just sayin
Old 10-14-2012, 06:07 PM
And jeez those are like $40 solder is cheap.
Old 10-14-2012, 06:19 PM
I agree, solder and heat shrink FTW.
Old 10-14-2012, 06:37 PM
When you guys are splicing 2 to 1 what do you use to heat shrink around those wires?
And how do you guys hook up to back of switches? Just a butt connector with the flat end to slide on?
Old 10-14-2012, 07:19 PM
Butt connectors are fine as long as you don't crimp on the seam. Once you do that, you ruined the connector.
Old 10-15-2012, 05:15 PM
It's sometimes hard to solder behind the dash...
Old 10-15-2012, 07:54 PM
cordless soldering pen works great for this...Easier to get behind the dash than the pliers you need to install the t tap.
Old 10-18-2012, 07:20 PM
Don't like them, the positwist i can use if a few wires but none of the other, cost to much and after time , the connection fails, this is the case when use with the wrong gauge wire,
Butt connectors are cheaper and takes less time , I also agree with everybody here, solder and heat shrink
