Remote Starter Problem/guestion.. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-28-2012, 07:33 PM Thread Starter
I just had a AudioVox APS57C installed and everything seems good but one thing. I noticed when I use the auto start my glow plug light does not come on during the 15sec delay before starting. It starts fine but its not cold out yet. When I turn the key to the on postion the light still does not come on. Is this normal? Are the plugs still heating up but no dash light?
Audiovox : Prestige : Remote Start Systems : APS57C
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
New UCF Heads ported & Oringed
Blue fuel spring
sinister coolant filter
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
EGT/ fuel/ oil psi gauges
Bilsteins Shocks
08+ Aluminum Axle Cover
08+ Trans Pan W/Filter
MTW stage 2 DD solenoid
24+ years Ford Employee
SharkDiver is offline
post #2 of 6 Old 09-29-2012, 05:01 AM Thread Starter
after more searching it appears this is normal.
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
Blue fuel spring
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
Bilsteins Shocks
post #3 of 6 Old 10-15-2012, 11:56 PM
codman02's Avatar
remote
Hey man,, my buddy has an 06 and is looking to put a remote start on his truck,, how do you like Audiovox? and where did you have it put on? ooo and what did it run you? you can PM me if you want to.
Thanks
Cody
'03 F250 Lariat FX 4X4 cc 7.3L gray/black
Fluidampner
Standcor GPR
ALL Thanks to Raul at
Superlift 2.5 leveling kit
Warn Premium hubs
Superlift dual SS streering stabilizer
EBC cross drilled & slotted, w EBC Green Stuff pads
codman02 is offline
post #4 of 6 Old 10-16-2012, 02:10 AM Thread Starter
I like it for a budget type auto start.. Whats really nice is my trk didnt have a key remote to unlock the doors stock but now I can use the auto start to unlock my doors. But it works good and has a long range.
I had it installed at CarTek in Valpo for $225.. I happy so far..
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
Blue fuel spring
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
Bilsteins Shocks
post #5 of 6 Old 10-18-2012, 08:14 PM
There is a wire from the remote start to turn on the light, but don't worry it is still working fine, the plugs are heating up
I have done over 50 remote star on diesel and only once connect the light wire
we never do that, it’s a lot of work to go behind the dash
aviator05 is offline
post #6 of 6 Old 10-19-2012, 08:03 AM
Actually, I've been reading that hooking up to the wait to start light on these trucks is a bad thing, and it would be best to use the timer functions. DEI specifies this (using the timer) on one of their tech sheets. It appears that this is what your installer did based on the 15 second delay before starting. If it was hooked up to the light, the delay would vary based on the time that the light stays lit. As for the light not coming on when remote starting, it could be that the circuit or circuits that power that are not being energized by the remote start. When installing a remote start you typically energize the circuits needed to start the truck and run the AC and heat.
67rstbkt is offline
