Help radio plugs - Ford Powerstroke Diesel Forum
Old 09-22-2012, 10:37 AM
Help radio plugs
Guys the idiot that owned my truck before me cut all the radio plugs off and spliced wires anyone know where I can get any harness or pigtails cutouts anybody got anything
Old 09-22-2012, 10:43 AM
what a dork the OEM adapter is like what 5 bucks ? splicing in the dash is a pain in the butt
your kinda screwed but if your getting a new deck your going to have to do the same now
or find a junk yard and cut off the oem and splice it back in ,, because that harness isn't a separate piece IIRC
Old 09-22-2012, 12:03 PM
I was hoping somebody Had put a custom deck in and still had the pigtails they would sell not too much of a chance that there's two dorks out there but you never know
Old 09-22-2012, 04:02 PM
Are you putting in a new aftermarket deck? If so try unplugging the harness out of the old deck and see if it will go into the new deck. If not, cut the plug off the harness and hardwire in the new deck. All you have to do is match color to color as all aftermarket decks use the same colors.(IE red is always power, black is always ground etc.) The hard part is done as you don't have to figure out what the colors mean in the stock harness. Even if you have the stock conector you still have to connect all the wires from the aftermarket radio to a adapter plug that connects to the factory plug.
Old 09-22-2012, 04:19 PM
Ok let me clarify I took out an adtermarket stereo. Im putting a stock radio cd back in. I need the plugs that plug in the back of the radio.
Old 09-22-2012, 06:28 PM
Junk yard is your best bet. From what I found online any 2003+ Ford uses the same plug as our truck's.
Old 09-25-2012, 12:42 PM
Check with a local audio shop. We (Best Kits) have the main plug only (24 pin). P/N BHO5800. I do not show the 8 pin plug.
