Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Electronics Discussion
Old 10-18-2007, 05:39 PM
3ddiver 3ddiver is offline
trailer disconnect
I am getting the trailer disconnect tone from time to time while towing. It does not happen when I do not have the trailer plugged in. I am using the 7 wire socket. Most of the time I do not get the message on the dash and the trailer does not turn red but sometimes it does. What is the truck looking at thinking that the trailer is disconnected. It does not look like the lights go out on the trailer when this happens and I have regrounded the trailer wiring.
Old 10-18-2007, 05:50 PM
dieselwrencher dieselwrencher is offline
Check to make sure the spades are in good shape, may need to spread them a little to ensure a good connection. One trailer of mine does it all the time, and I finally found out it is bad trailer brake solenoids on my trailer, so I unhooked the wire because that thing dinging drives me nuckin futs. LOL
Old 10-19-2007, 06:19 PM
Blue01F250 Blue01F250 is offline
Tournaments Won: 1
Make sure you have a good connection on your trailer plug and that your trailer light wires aren't too short that when you drive it pulls the plug out slightly during turns and such
Old 10-19-2007, 07:54 PM
Marv Marv is offline
3d, I've been fighting the same problem for over a month now. Tried different adaptors (trying to go from 7 blade to six pin) and still no luck.
Actually went today and had all the wiring checked out and it seems everything is okay.
Long story short, I'm thinking the Ford OEM controller just isn't working as it should. I think I'm going to just put a Prodigy in the truck and be done with it.
Good luck.
Old 10-27-2009, 11:22 AM
1Reaper 1Reaper is offline
So has switching to a 7 prong fixed the problem? Or does it need a 6 prong wired correctly?
