Multiple cameras - Ford Powerstroke Diesel Forum
post #1 of 25 Old 08-12-2012, 12:40 PM Thread Starter
Quoted: 3 Post(s)
Multiple cameras
I am putting in a 7" Nav/Stereo in my '07. It has a hookup for a backup camera. I am thinking of putting a camera on the front also. Kind of to help when pulling into tight short parking spaces since the truck is so tall it's kinda hard, for me at least to gauge my distance. Anyways I was thinking of maybe installing a relay with diodes and a video in splitter so that when I shift into reverse I get the backup camera and maybe hook one of the upfitters so that when I switch it on I get the front camera. Anybody done this before??? Anything I'm missing in my logic? Any I deas?
Steve
'07 F250 King Ranch
Upfitter switches
High Idle Mod.
DIY Coolant Filter
ScanGauge II
"The Little Blue Spring"
Full coolant flush - now running CAT ELC
New oil cooler, standpipes & dummy plugs, 6.4 Banjo bolts, STC fittings
EGR Delete
SCT Tuner running "Looney"
Edge Insight with EAS-EGT
Rotella T-6 5W40 and Rev-X
4x4ff is offline
post #2 of 25 Old 08-13-2012, 07:56 AM
Not really any need for relays and diodes. A video switcher will have a positve or negative trigger that can switch to the 2nd input by the upfitter switch, then run the output to the headunits camera input.
2006 F250 PSD-Fabtech lift,King Coil overs,AMP steps,37's,some other bolt ons.
1965 Mustang Fastback-
Sound Decision Car Audio-MECP Certified
Ford Master Tech
iskwezm is offline
post #3 of 25 Old 08-13-2012, 12:37 PM Thread Starter
Quoted: 3 Post(s)
Thanks, Do you have a brand or a link for the switcher?
Sent from my DROID BIONIC using AutoGuide App
'07 F250 King Ranch
Upfitter switches
High Idle Mod.
DIY Coolant Filter
ScanGauge II
EGR Delete
4x4ff is offline
post #4 of 25 Old 08-13-2012, 01:08 PM
jluv's Avatar
Quoted: 29 Post(s)
Does your head unit have aux input in addition to a dedicated camera input?
If so, just hook them up that way, and switch to the aux setting when you need to use the front cam. Otherwise, how is your head unit going to know which signal to accept if you wire two cameras up to one input? I'll bet the picture quality would also suck if you have to use a splitter to bring both video inputs into one port.
Also, if you hook a front cam into an input port made for a rear cam, your picture will be "backwards", so stuff to your left will be on the right side of your screen, and vice versa. If you run a front cam into an aux input, you shoudln't have that problem.
jluv is online now
post #5 of 25 Old 08-13-2012, 01:18 PM
I dont like to push our companies products on forums, but we have the VA26, 2 inputs and 6 outputs.Pac-Audio.com Product Search | iPod Integration for your car and More by Pac-Audio - Connecting you to the future
Video image would not "suck" as this is also a video amplifier. There are cameras that have reversible images to be used in front or rear applications
Ford Master Tech
iskwezm is offline
post #6 of 25 Old 08-13-2012, 02:37 PM Thread Starter
Quoted: 3 Post(s)
Good input guys. I am getting (Don't have it yet) an Eonon G2216. Before the bashing starts I know I should get a Kenwood, Pioneer, JVC, etc.,etc.,etc. But these are reasonably priced and have had some good experiences with the 'cheaper' radio's in the past. I am not really an audiophile per se.
Now with that out of the way here was my thinking.
There is a dedicated port for backup video (you can mirror image it on the radio) with a wire that senses when you go into reverse. It just picks up power from the back up lights and switches the radio to that video input. There is also an AUX video input but it has to be manually selected from the radio.
The reason I was thinking of using diodes and a splitter was this: If I shift into reverse the power from the backup lights turns on power to the camera and also causes the radio to auto switch to the video display. I was going to run power from one of the upfitters to the front camera and also to the sense wire on the radio (The same one where the wire from the back up lights is hooked to). Hence the reason for the diodes. If I flip on the upfitter, it powers the front camera and turns the radio to the correct display with the diodes keeping power from feeding through to the backup lights. When I put the truck in reverse again power is sent to the rear camera and to the sense on the radio with the diode keeping power from going to the front camera. The only issue could be if I was in reverse and switched the upfitter on.
See what I'm saying??
Steve
'07 F250 King Ranch
Upfitter switches
High Idle Mod.
DIY Coolant Filter
ScanGauge II
EGR Delete
4x4ff is offline
post #7 of 25 Old 08-13-2012, 03:30 PM
jluv's Avatar
Quoted: 29 Post(s)
Steve
On my Alpine, it also automatically switches the view to the rear view cam if you put the vehicle in reverse, BUT the video signal from the cam is constantly being sent to the head unit, and you can manually select that view at any time. Ya, you could probably rig up a video switcher and somehow use the upfitter switch, but it seems like the long way to go about it.
Do you already have something you're wanting to connect to the aux input of the head unit? If not, why not just hook up your front cam there and keep the rear view cam the way it us? You can then manually select the front cam (aux) view from the touch screen about as easily as you could kick on the upfitter switch.
This way, you don't need a video switch, diodes, a reversible view camera, etc, the wiring will be very simple, and you can save the upfitter switch for something else.
jluv is online now
post #8 of 25 Old 08-13-2012, 03:36 PM Thread Starter
Quoted: 3 Post(s)
This way, you don't need a video switch, diodes, a reversible view camera, etc, the wiring will be very simple, and you can save the upfitter sworn for something else.
Dang jluv,
You make a good point. I'll just keep the front camera powered all the time and use the aux input and skip the upfitter all together. Makes perfect sense.
'07 F250 King Ranch
Upfitter switches
High Idle Mod.
DIY Coolant Filter
ScanGauge II
EGR Delete
4x4ff is offline
post #9 of 25 Old 08-13-2012, 04:03 PM
jluv's Avatar
Quoted: 29 Post(s)
Dang jluv,
Glad I could help. I have been thinking of doing this same thing for a while. Since I added a light bar on the front, I get nervous about inching up too far sometimes. Haven't hit anything yet, but it would be nice to know exactly how much room you have.
jluv is online now
post #10 of 25 Old 08-25-2012, 06:05 AM
mtpolarbear's Avatar
Steve
I run five different cameras on my rig, rear license plate, rear of travel trailer, inside of travel trailer, inside and out side of cargo trailer and just use a video switcher and have it sitting between the drivers seat and the middle seat and works great. Easy setup and zero issues. I bought the camera from Amazon for $22 each. They tie into the camera port on my Clarion Stereo. I can post some pics if you like.
POLARBEAR - 2003 F-250 SD CC SB FX4, 6.0, 3:73 gears, EGR & Cooler Delete, Bulletproof Oil Cooler, ARP Studs, A.R.E. Topper, Bedrug, Zoodad, 5" Magnaflow turbo back, K & N cold air intake, coolant filter, EDGE INSIGHT CTS, SCT X3 Tuned by Vivian, Energy Suspension Master Bushing kit, RiffRaff Boots, Blue Spring, 6.4 Banjo's, Fumoto Oil Valve, Fumoto water drain plug, Whistler 2000 Watt Inverter, DC Power 200amp Alt. Rebuilt FICM w/Atlas 40, Riff Raff Boots and counting.
mtpolarbear is offline
