Ac stuck on high - Ford Powerstroke Diesel Forum
Old 08-10-2012, 01:03 PM
Ac stuck on high
Bad luck this week with the truck. My fan is stuck on high. I can adjust temperature but not fan speed. It also stays blowing even when I turn the air off it just moves to the defrost vents on top of the dash. The only way to turn it off is to shut the truck off. Any ideas what could be causing this?
Old 08-10-2012, 03:47 PM
Does the display change on the A/C control head if you lower the fan speed? If it does change but the fan doesnt, it could be a bad blower speed resistor, but since you said the air goes to defrost, it sounds like the A/C control head itself.
Old 08-10-2012, 03:54 PM
Yes the display changes but fan speed does not. Temp changes also.
Old 08-10-2012, 07:30 PM
Blower Problems
Hello, your symptoms sound similar to mine. Hope this helps.
Sent from my DROID Pro using AutoGuide.Com Free App
Old 08-11-2012, 08:29 AM
Originally Posted by rr06psd View Post
Blower Problems - Ford Powerstroke Diesel Forum
Thanks! Ill look into that
