| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
How do you hook up a remote start on a 6sp?
Does anyone know how to bypass the clutch safety switch on a 2004? Trying to figure it out??
Go to 12volt.com and do a search . There is posts about it with pics from directed .
Sent from my iPhone app |
Couldnt find it, if you could post the link I would greatly appreciate it
is the kit you have made for a manual trans truck? if not i wouldnt consider installing it.
do you know what kit is manual specific?
Although you probably already know you shouldn't install a remote start not designed for a manual trans truck, what you need to do is hop under the dash, and at the clutch there should be a switch. Take a multi meter and test the wire, check which one you see a change in, after you do this you will need to hook the status wire, if its a DEI remote start (Viper, Avital, Python, etc.) it is a blue wire with a white tracer. this wire puts out a positive signal, if your clutch test as needing a negative signal, you'll need to use a relay.
Good Luck, and remember, always keep it in neutral. |
