| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Fog light addition?
Good evening...or morning or afternoon depending on when this is being read. I've searched around a bit for what I'm asking but haven't found an answer yet...I I've missed something in the forums here I apologize. This whole ford ownership thing is a very new experience but I'm not regretting a thing thus far. I have an 06 f550 xlt that does not have fog lights. What would I need to do/purchase in order to put factory fogs in the truck? Is there a kit with the harnesses I need, the lights and new headlight switch? Is it mainly plug and play?
Again I apologize if there is somewhere I should be looking for this answer or if I'm posting in the wrong place! Sent from my Autoguide iPad app |
I bought this one from ebay a year or so ago. It's a factory upgrade kit, so it's Ford. Installation is pretty straigh forward, mount lights (bumper has mounts already,) run harness into the cab and the power to the battery. Then put the pin into the existing headlight harness, then pop in the new switch. A little tip on the install of the fog lights themselves, if you have a front license plate bracket, you can just bend down a little bit of the metal bumper to get the fog light brackets in. Then the license plate bracket hides the bent metal. Otherwise you'll have to remove the bumper. Good Luck!
www.ebay.com |
