"Dinger" won't stop - Ford Powerstroke Diesel Forum
Old 06-22-2012, 07:07 PM
"Dinger" won't stop
06 f-350 SRW King Ranch FX4. You know that annoying sound that starts when you open the door and the keys are still in the ignition? Well mine doesn't stop when u take the key out. It stops only when I shut the door. Doesn't really bother me just wondering if it may be doing that for any reason? Letting me know something is wrong? I don't know. Any help is appreciated. Thanks.
Sent from my SCH-I500 using AutoGuide.Com Free App
Old 06-23-2012, 05:03 AM
i have a 05 and it does the same thing. my father in law is a ford tech and he said it has something to do with the ignition. still havent figured it out?
Old 06-26-2012, 11:38 AM
remove the key cylinder and there is a brass tab that make contact with the key.See if that is bent. (to remove the cylinder, turn the key to the "ON" position and under the column theres a hole to press the relese detent,press and pull the cylinder out.)
Old 07-04-2012, 04:59 AM
The little tab thingy in mine was messed up. I just pulled it out & taped it up. No more dinger.
You'll likely need to pull the upper & lower steering cowl off to see everything. They're only held in by 3 screws. Pull the cylinder, pull the upper/lower cowl & you'll see everything.
Old 07-10-2012, 04:44 PM
New "dinger" switch part number is XL3Z-11A128-AA. Should be about $20. When you pull ignition cylinder out (super easy) you will see a small metal tab on a little black plastic piece (that is the part). It is on the lower left side of the hole. Mine is an '05 and the wire is black with a pink stripe. Just ordered mine Monday.
