| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
power to my backup camera
I know this is really elementary but where is the best place to grab power so that I have key on power to my back up camera. Do I go to the underdash fuse box and try to get a wire into a fuse some kind of way? I know this is probably something pretty novice but there ya go, I am a novice on electronics. Thanks all for your help
forgot to mention it is only a 22ga wire |
ok, how about this. Is there key on power under the hood near the upfitter switch tie ins?
I tied mine into the back of the fuse block (drivers side under the wheel) remove 4 10mm bolts and the wire is in the lower right corner (looking at the fuses) it is a black and pink wire it is your reverse lite trigger. Camera comes on when you but it into reverse.
camera is at the back of the truck why not tie into your reverse lights in the rear light harness.
i dont think thats what waumpuscat was wondering, if i assume correctly he wants his camera to turn on while he/she is starting the truck to see behind and make sure of their surroundings |
Typically u should be able to run it into ur reverse wire under ur dash. There should be a standby option on the camera also to lower the power down to a minimum when not using all of our tow trucks are direct power and cameras switch on in reverse
And that relayed the video signal??
are we talking about aftermarket or installing OEM into your truck?
I put a 2010 F-150 camera and lcd mirror into my F-250. It's powered/grounded off the 7-pin harness. anytime the truck is running, it's powered. the rearview has a reverse trigger wire that tells it to energize the LCD in reverse. awesome setup IMO. just wish it had been available prior to 2008 edit: I powered mine deliberately that way because after looking at the Ford schematics, the OEM camera is powered at all times as well. at some point I'll quit being lazy and will trigger the LCD off an upfitter as well so I can use it while driving forward. just too lazy to install the diode at the moment Last edited by Tylus; 07-08-2012 at 05:19 PM. |
Did you have to run a video cable?
