Horse Trailer Camera Interference - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-04-2012, 05:03 PM Thread Starter
Ok, so I don't know how many of y'all will be familiar with a camera used in a horse trailer to watch horses going down the road, but I figured I would ask. So, I have it hard wired through my display on my dash, back thru the cab, over the wheel well, then back up through the bed, where it hooks into the connection attached to the trailer. It's a standard white/yellow A/V cable hooked into my amp/"brain".
The problem is, I'm getting a lot of interference when I hit the brake (ie, squiggly lines across the screen). I initially zip tied the cable very close to the brake light cable (unintentionally). I repositioned the cable away from the brake lines/cables, but still getting the interference. The camera cable is still pretty close to the brake light as it runs up close to the tailgate on the driver's side and into the bed. I'm thinking it's still interfering there.
Is there any way to wire it into the plug for the trailer brakes/lights? Then put the camera cable from the trailer into the trailer plug? Hope this isn't too confusing and complicated for ya. I'm no electrician by any means.
Thanks in advance for any/all advice!
C17pwrstroke is offline
post #2 of 8 Old 06-05-2012, 05:19 AM
hogasm's Avatar
Check to see if the cable is shielded
If not it is possible that any electrical bleeding will cause interference
I'd rather be fishing
hogasm is offline
post #3 of 8 Old 06-05-2012, 05:24 AM
Snake's Avatar
Quoted: 46 Post(s)
I know exactly what you're referring to, and you're going to have to either shield one of the wires or re-route them. A ferrite bead might help also.
Snake is offline
post #4 of 8 Old 06-05-2012, 05:14 PM Thread Starter
Thanks for the input guys! But, I can't tell if I am getting interference from the truck or from the trailer. I suppose that means I need to troubleshoot to find out where its coming from first, then shield? or should I shield the whole thing? Either way, shielded conduit is REAL expensive isn't it? Thanks again!
post #5 of 8 Old 06-05-2012, 05:23 PM Thread Starter
I guess one way to tell if it's from the truck or trailer brakes is to hook the trailer up, then turn the brake controller for the trailer all the way down to where there's not any braking going to the trailer. Or do you think that even with it turned down, there will be an electrical current running to the trailer brakes? I suppose there would be, which wouldn't help me any.
post #6 of 8 Old 06-05-2012, 05:24 PM
Snake's Avatar
Quoted: 46 Post(s)
Yep, gonna have to troubleshoot first, then figure out what needs to be shielded. The best bet may be to try to re-route the wire on the truck (pull it as far away from the truck as possible) and potentially try to wrap the wire in aluminum foil to see if that solves the problem.
Snake is offline
post #7 of 8 Old 06-05-2012, 05:35 PM
Quoted: 2 Post(s)
What 12v source does your camera get its power from?
2006 F350
6.4 banjos
FP spring
Insight CTS
IDP/Looney SCT X3
Studded
Durastroked
S&B,CCV
FICM Repair/PHP 40hp
2008 F250 FX4
DPF-R +
06DZL is offline
post #8 of 8 Old 06-08-2012, 09:30 PM
Run a seperate ground wire for camera. Had same problem on my reverse camera and back up alarm both getn same power and ground. Ran seperate power -same. Ran different ground same power -fixd
zzamud is offline
