| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Sub-box help
Ok. I spent all afternoon building a box for my 2 10s the other day based on specs i've read on here. they have a 5" mounting depth so i made the box 6" on bottom and 5" up top and 48" wide. The magnet was almost touching the back of the box with the speakers mounted as low as i could get them.....got it all done and THE FREAKING SEAT WONT LOCK BACK....
any guys with an 06 lariat put any boxes behind their seat? I have 2 vents back there that are giving me problems as well as the window motor. any help would be appreciated! |
you have to remove the vent and cover it with some dynomat or something similar
mine fit without removing the vent i did however order mine online instead of building it myself. only thing i had to remove was the carpet material on wall behind the seats
where did you order the box from? what was the speaker depth on your box?
got it from here Ford*F-250*F-350*Crew*Cab*Powered*Window*2004*-*2012*Dual*10"*Custom*Sub*Box*Enclosure...
i used rockford fosgate p3s subs they are shallow mount regular subs will not fit |
I removed/covered the vents on mine as well. I have two shallow mount Alpine 12's behind the seat. Even with the vents removed I had to modify the back of the box so the magnets would have clearance. I flush mounted the subs with the front of the box, if I had just mounted them on the front of the box I would not have had clearance issues.
I'm looking at starting to collect parts for sub and speakers. So 6inch of depth is acceptable in the back?
what year is your truck?
6"max for the box |
Mine is an 03. Also sticking a compressor back there too
I removed the vent and replaced with hushmat.
I just built the box to fit around any obsticles. now i did cut the back carpet hump that covers the vent. I recommend the hushmat over other sound deading material this is why |
