Laptop isolation - Ford Powerstroke Diesel Forum
Old 05-26-2012, 08:52 AM
Glow Plugs Only
Question Laptop isolation
Heres one for the electronics guy's. I was reading through the information with the AutoEnginuity laptop software and it mentions that if using the laptops power cord to be sure it has an isolated cicuit to prevent a ground loop which could damage the ECM or laptop electronics. Would using an inverter to plug the laptop into be considered an isolation transformer or would an isolation transformer in conjuction with the inverter be required?
Old 05-26-2012, 08:55 AM
I never chance it I run off of Battery when I use mine ,,
probably an Idle threat but a CYA disclaimer I bet
you can always shoot them an email ,, they are good at responding
Old 05-26-2012, 09:05 AM
Glow Plugs Only
I'm with you on that one. I always run it off battery but on long trips if I want to do some monitorring it may be an issue. I think I will send them an e-mail and see what they say.
Cheers
Old 05-26-2012, 09:23 AM
Glow Plugs Only
Just went to the AE site and drilled down through the FAQ's to some rather disturbing photo's they have posted showing the damage which can occur without an isolated ground. Think if I need power while it's connected to the OBDll it'll be my jump booster powerring the computer so there is absolutely no chance of a ground loop.
Cheers
Old 05-26-2012, 09:45 AM
can u link to them I was just there and couldn't find them?? oh I am sending a PM to ya also for another favor
Old 05-26-2012, 09:57 AM
Glow Plugs Only
I went here and then the FAQ's and answered the PM as well
Cheers
Don
AutoEnginuity® - OBD2 Scan Tool - Professional PC and PDA Diagnostics
Old 05-26-2012, 10:00 AM
Thanks a Ton ! ! !!
Old 05-26-2012, 10:02 AM
Old 05-26-2012, 03:06 PM
Glow Plugs Only
Scary stuff. I don't wanna even attempt it
Old 05-28-2012, 07:46 AM
have you tried the Laptop charger bypass kit from Walmart? GE Indoor Outdoor Extension Cord 50' Extension Cord, General Purpose Extension Cord, Grounded Extension Cord
worked great when i reflashed my NAvi and was too lazy to get into and out of the truck a dozen times
