Gauges...... - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-25-2012, 08:12 PM Thread Starter
Gauges......
Excuses my ignorance. I'm sure this topic has been beat to death. I want a good set of gauges. I don't know much about which is better digital or analog. I would like to be able to monitor engine oil temp, coolant temp, trans temp, and possibily exhaust temp. I don't have a programmer/tuner, nor am I interested in one. I just want to be able to monitor the trucks vitals....any suggestions?
03superstroke is offline
post #2 of 7 Old 05-25-2012, 08:42 PM
try the search button, but i bet you have, but analog guages are nice, but you can only moniter one thing per guage, so i would recommend digital. You can purchase an edge cs or cts, a scan guage, and multiple other options, now keep in mind, that these will only monitor, not tune
levan4076 is offline
post #3 of 7 Old 05-25-2012, 10:24 PM
Term3's Avatar
I love my Dakota Digital gauges. Especially at night.
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #4 of 7 Old 05-25-2012, 10:26 PM
back to business
07OUTLAW's Avatar
CS or CTS will probably be the the best bang for your buck. You will have to get the EGT probe add on and I'd suggest fuel pressure too.
If you want analog, Isspro is the way to go . But, plenty of folks have had good luck with autometer and some use glowshift.
Duane
2007 - F-250 Lariat OUTLAW
1983 - MERCEDES-BENZ 300D
07OUTLAW is offline
post #5 of 7 Old 05-25-2012, 10:30 PM
Term3's Avatar
Found a couple pics. Not the greatest quality of pics as I used my cell phone
ID:	38397   Click image for larger version
Term3 is offline
post #6 of 7 Old 05-26-2012, 08:42 AM
Glow Plugs Only
dee004's Avatar
I don't have one but the scangauge ll is a good value and allot of the guy's on here use them. They're fairly compact easy to mount and hookup to the OBDll port as well as reasonably priced around $149
05 F250 CCSB 4X4, 05 VW TDI
4"Banks Turbo Back, ARP Studs & OEM Gaskets,
Coolant Filter, Blue spring, Zoodad
Bypass Oil Filter, Kitty By By, Standpipes dummy plugs
BPD oil cooler, EGR Delete, CCV Mod, BPD Oil Cooler, SCT SF3
dee004 is offline
post #7 of 7 Old 05-26-2012, 09:18 AM
The Silent Service
colo_dually's Avatar
Quoted: 10 Post(s)
I run a set up of the Edge Insight CS and Autometer guages.
The deciding factor for me expanding to the monitor, vise a few more gauges was monitoring of FICM Voltage. A leading cause of fuel injector failure on the 6.0L. This simply cannot be monitored via a traditional gauge.
Bang for the buck is the Edge Insight CS, I'm not huge on the ScangaugeII, though it is cheaper. You can expand the Insight to read EGT and Fuel Pressure later on as funds become available, or opt for traditional gauges for those.
Here's a pic of my set up, any questions let us know.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
