| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Flashing "tow haul"
This just started today. Driving along just fine, 60 mph (in a 65 zone) and two things happened.
1. "Tow haul" starts flashing. (it was not engaged at the time) 2. "trans temp" gauge drops to flat. I pulled over, shut the engine down, waited, started, and all was normal. Any ideas? Thanks in advance. Sent from my Autoguide iPhone app |
Wow, I can be oblivious...
Truck is a 2004 F350, Dually, 6.0 Thanks Sent from my Autoguide iPhone app |
scan it to read the codes
it is probly the trans fluid temp sensor, mine did that and i had to replace it. |
Great suggestion, thank you. Checked codes, and the sensor is indeed bad. Unfortunately, I'm on the road, towing a 5th wheel, and looking at the manual, this is a fix I can't do until I get home. (no tools, etc)
I'm guessing that if the trans temp sensor is going out, then towing in this condition is probably not smart. Thoughts, anyone? thx |
If it's just the sensor, I wouldn't worry.
Heck, I'd rather not even have it. Once it gets to the red, you're already overheated. |
I'm wondering if the PCM would have a different shift strategy and possibly defuel due to a failed trans temperature sender?
will see how it goes in the morning. |
Closing the loop.
Indeed a faulty trans temp sensor. btw, price on those has dropped a bunch: they are $20 now. Ford redesigned it. Sent from my Autoguide iPhone app |
That's good. How much labor
I made my Samsung SGH-I997 send this. |
Ford dealer replaced the temp sensor, and changed the trans fluid (8 qts.) Total cost was ~$270.
fwiw, and I only have this one data point, I was pleased with the service at Rogers Ford in Midland. Terry service manager, Stefan diesel tech. Got me in first thing, out before noon, even with a bunch of PSDs in front of me. |
