radio display inop but radio works - Ford Powerstroke Diesel Forum
Old 05-03-2012, 03:19 PM
The backlight for the radio quit working but still funtions properly. I can turn on/off change stations and all presets still work, just the display is dead. No clock, or anything. The only lights i get are two little led lights from the CD player. Is there some fuse somewhere to check or is the radio needing replacing? Thanks
Old 05-03-2012, 03:32 PM
Chapter Director
Send a message via AIM to Fantom
I think it's just the display is dead. If it were a fuse, the radio wouldn't get any power at all.
Old 05-03-2012, 03:45 PM
I have My old one from last years upgrade
and it's in good shape and in shipping mode ( most folks don't know it has that option ,,lol)
$75 pay pal and + shipping via ups signature required .
otherwise if yours toast and want , upgrade? and spend a couple $100 more ??
I have suggestions
Old 05-03-2012, 03:47 PM
Feedback Score: 3 reviews
I have a problem similar to this but it's the other way around. My radio is getting power to it but it will not turn on. All the lights on the buttons light up and when you press the power button the screen comes on shows the ford logo and time and then shuts off. Also none of my windows work. This seems to be a delayed accessory problem but I checked all the fuses for radio, windows, and delayed accessory and they are all good. How would I go about checking the big cube looking relays? I think that could be the culprit
Old 05-03-2012, 03:48 PM
Chapter Director
unless his truck's an 03-04
Old 05-03-2012, 04:52 PM
I have an 03..... I checked the only radio fuse which was of course good. Man you dont realise how often you look at the clock until you dont have the clock!!! I going to check at a local salvage yard and see if they have any radios still in workin order. Thanks for your replys!!!
Old 05-03-2012, 04:55 PM
I have suggestions
Thanks for the offer!!! I will check the local salvage yard and see if they can help and if not I will get hold of you. Will the 03 and 06 radio be compatible?
Old 05-03-2012, 06:44 PM
It's a cracked solder joint on the back of the display board more than likely.I have fixed a lot of the on expeditions and f150's never seen it happen on an F250.
all you need to do is pull the radio,take of face plate,resolder all solder jonts and test
Old 05-03-2012, 08:16 PM
I don't think so ,, sorry I didn't notice the year if it was posted ?
