Wiring of tranfer tank pump - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-21-2012, 01:03 PM Thread Starter
Jeffcosta423's Avatar
Just installed an auxiliary fuel tank and don't know how to wire the pump to one of the auxiliary switches in truck. Want to be able to shut pump off inside cab.
Any advice? Thanks.....
Jeffcosta423 is offline
post #2 of 4 Old 04-22-2012, 10:36 AM
van-boy's Avatar
are you refering to a tidy tank and the upfitter switches.
bailey
cut me some slack, its a work truck.
van-boy is offline
post #3 of 4 Old 04-22-2012, 11:05 AM Thread Starter
It's a transfer tank with a full rite pump to full up the machines on a construction site. My previous truck was wired to the upfitter switches and not sure how they did it
post #4 of 4 Old 04-22-2012, 03:57 PM
van-boy's Avatar
i have the high idle mod which i have done with the help of the people on the org. my pump is directly hooked up to the passenger side batt all the time with a plug so i can unplug it if i park in shaddy areas. use the seardh and upfitter switches and you will find what you want. i always use the high idle when using the pump.
bailey
van-boy is offline
