Two electrical questions - Ford Powerstroke Diesel Forum
Old 04-15-2012, 12:47 PM
1 - Does the factory radio slide out 'with' or 'without' removing that piece of the dash?
2 - Chicken lights. The ones above the windshield and on the rear of hatch (i drive an excursion). Where does one go to have those installed? (if I do it they'll end up crooked. its just a fact. haha)
Thank you.
Old 04-15-2012, 06:35 PM
1-with removing
2-I would still do it myself. Even if it is crooked I would still feel good that I did it myself
Old 04-15-2012, 06:52 PM
My radio pulled out from the front. 2003 if that makes a different from other years.
Sent from my PC36100 using AutoGuide.Com Free App
Old 04-23-2012, 01:48 PM
I have a 2004. The radio comes out as a single unit, face plate and all. Go to the auto parts store, and buy this inexpensive kit that has two big U's in it. Will probably be in the radio/stereo section. You push them both into the holes on each side of the radio, at the same time. You only push in until there is a slight click- don't push all the way in or it won't disengage the latch things. Then you hold both of the big U's and pull out the radio. Once it's out a little bit, you disconnect the cables.
The holes are vertical.
This worked for me. Hope it helps.
Old 04-23-2012, 07:51 PM
Glow Plugs Only
Once you pull off the face of the dash the stereo is held in with four small bolts.
