03 6.0 fuel light - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-25-2012, 11:28 AM Thread Starter
03 6.0 fuel light
My 03 6.0 fuel light with little rain drops came on. Can Anyone give me advise on this? I dont have a owners manual. Thanks
bigboy21 is offline
post #2 of 4 Old 03-25-2012, 02:29 PM
06SuperDutyF250's Avatar
Water in Fuel, go underneath your truck on drivers side framrail and drain the Fuel Module, its a 6m allen i think
06SuperDutyF250 is offline
post #3 of 4 Old 03-26-2012, 04:46 PM
asian195's Avatar
Quoted: 2 Post(s)
change your fuel filters also while your under there.
2003 F-350 6.0L.
Leveling kit
35/12.50-20 Federal Couragia M/T
20x10 black Fuel Hostage wheels
4"-5" exhaust no cat
Airaid intake
SCT tuner-awaiting custom tune
Edge Insight CTS
Blue spring
6.4 Banjo bolts
Zoodad mod
EGR Delete
To Do/Wish list:
FICM tune
ARP Head Studs
BPD Oil Cooler/Filter
Fog light mod
Harpoon mod
Injectors 155cc
asian195 is offline
post #4 of 4 Old 03-26-2012, 05:01 PM
Lilfarmrboy's Avatar
Whatever you do don't keep running it or else it may take out your injectors. The drain is under the driver side door on the inside frame rail. You can't miss it. 6mm allen wrench and as stated go ahead and change that filter on the frame rail and the filter besides the oil filter canister on the motor. You can go to http://www.dieselfiltersonline.com/D...ence-Guide.pdf
for a good write up and order the Racor filters (the same that make motorcraft) and save some $$$
Lilfarmrboy is offline
