| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Resistors for L.E.D Bulbs???
Just threw on some aftermarket tail lights and swapped the bulbs to LED's. Now turn signal blinks @ 2x normal speed. Do i need to put a resistor inline somewhere and if so, what size?
Oh Ya... Dont buy cheap taillight off of fleabay unless you like to modify stuff with a roto-zip...lol Thanks, Todd |
Get an electronic flasher relay.
Ok..i know nothing about this stuff, are there different ones or are they all 3 prong. the info on the one I found has this:
Car LED blink flasher with 3 pin for cornering lamp Part NO.: CF13 JL-02 This will solve LED related turn signal problems such as rapid flashing, not flashing, or bulb burnt out warning on dashboard Pin Length: Approx. 0.47 inch / 1.2cm Voltage: 12V Power: 240W Switch Current: 0.02 - 20A Size( L x W x H): Approx. 1.2 x 1.2 x 1.2 inch / 3 x 3 x 3 cm |
Idk which one your trucks. You'd just have to pull it and find the one that matches it.
LED Flasher Unit EP27L Specifications I think this is the one. |
Go here: Retro-Solutions.net
