| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Are these DTC's anything to worry about???
I got the following DTC's when I checked them this morning....
P0405 - EGR A CKT Low P0603 - Internal Control Module Keep Alive Memory (KAM) Error P0683 - Glow Plug Control Module To PCM Communication ckt P1000 - OBD System Readiness Test Not Complete When I got home after driving this evening they all were still present. I tried to clear them and the P0405 and P1000 stayed but the other two are gone. Any ideas? Thanks Dave |
Try to unplug the egr valve then plug it back in. If it goes away great, if not you might need a new EGR valve. I had the same code after i replaced #7 injector, I must have bumped it unknowingly. plugged it back in and was good to go!!
Good Luck, Todd |
Todd,
I don't have an EGR valve. Mine was deleted a while ago. |
