Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Electronics Discussion
Old 09-16-2007, 01:38 PM
0660 0660 is offline
CB Antenna?
I'm looking for pics of mounted antenna's. I cant seem to find a good spot. I have a tool box, but it's a low profile, so no room.
Old 09-16-2007, 01:51 PM
strokermann strokermann is offline
is it mag mount or hard mount
Old 09-16-2007, 02:14 PM
SMKSTAX SMKSTAX is offline
KCR DIRECTOR
I heard the Wilson 5000 magnet mount's are good. Mount it on your roof.
Old 09-16-2007, 03:45 PM
StarDriver StarDriver is offline
The only thing bad about mag mounts are that they leave marks where you had them. I'm trying to figure out where I'm going to put my antenna.
Logan Logan is offline
The Fat Mod
I have my wilson mounted in the middle of my back window. Just bolted to the bed rail.
Old 09-16-2007, 03:47 PM
a lot of people have them mounted on teh hoods here back nearthe wiper blades if you know whati am talking about
Old 09-16-2007, 04:00 PM
Ditty Ditty is offline
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
Remember...the placement of your antenna is going to havea hand in your reception. The closest you can get to the middle of the truck, the better. Also make sure the antenna height is right. 1/3 to 3/4 of the antenna's length should be above the highest point on the truck. Dual antennas are a different animal...I would research duals and the correct placement if that is what your looking for.
In a perfect world, I would install a 104" whip with the base as high as possible, like on the top of the cab...in the middle where the 3rd brake light is.
Also...make sure you ground the antenna and mount the best you can.
Old 09-16-2007, 04:50 PM
bigcountrysg bigcountrysg is online now
duct tape & zip ties
Yeah that as well as getting the antenna matched to the radio. If you don't have the antenna matched to the radio you will burn up the radio. Then you will be looking for a new radio.
Old 09-16-2007, 05:09 PM
running dual is a waste of money imo. unless you are running multiple antenna for cb competions. here is a pic of my old jeepabout 4 years ago at a cb competion.
Old 09-16-2007, 05:25 PM
kornfed kornfed is offline
I just mounted mine on the sides of my tool book and they work fine, I don't have any problems with reception.
