| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
new to SD how do i use my upfitter switches
i just got my 05 with the factory switches and i was wondering where im supposed to hook up the wires to on the upfitter switches to make them work,, my first mod will be a high idle switch on switch #1 all info is helpful lol thanks!
Im not sure how you hook em up but I know the first 2 switches are 30amp and the other 2 are 10amp i believe. Better off with 3 or 4 for using the high idle mod. sorry i cant help with how to hook them up tho.
from what ive read on here the wiring should be above the fuse panel. Heres the link I found for the high idle mod
TheDieselStop.Com - www.thedieselstop.com I would also suggest using switch 3 or 4. Save the first two for higher current applications ie. lights etc... |
There is a fuse block located behind the glove box for the up fitter relays and fuses. You can open the glove box and push in on the sides to let the door flip all the way down for access. You will not need to access these unless you are changing the fuses and/or relays for the up fitter switches. The wiring from switches can be accessed by lowering the main fuse block below the steering column. Once the fuse block is lowered, you will find (4) wires that are cut and taped up(wires are all orange but have different color tracers for identification). Theses are the switch legs from the up fitter switches. You can simply splice on to the one you want and power up your accessories. The owners manual will tell you the color codes, but still a good idea to verify with a voltmeter or test light to get the switch you want. I would also recommend going with switch 3 or 4 since they are the 10A switches. Hope this helps. Good luck.
will it cause any problems goin on switch 1 being a 30 amp this will honestly probably be the only upfitter switch i ever use and switch 1 will be handiest thanks guys
You wont run into any issues using switch 1. Its just a little over kill. If you dont plan on installing lights or anything, then you may as well use it. You can always swap later if needed.
https://www.fleet.ford.com/truckbbas...rical_v1.1.pdf
Look at page 4, it lists the wire colors as well as fuse values for each switch. The wires are located under the steering colum on the drivers side. |
Is there any way to convert the upfitter switch to a 3-way switch? Or replace the switch with a 3-way? Benefit to doing this is so that I can put in 08+ mirrors on the truck and wire the switches to power fold and telescope using the switches and leave everything on the driver side door stock (clean look)
