high output alts - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-22-2011, 03:07 PM Thread Starter
scotty2280's Avatar
high output alts
anyone have any suggestions? im leaning twords alternatorparts.com but was wonduring if anyone have any exp with others. ( not going with db either)
studs,egr delete(sinister),dieselsite coolant filter, nuc oil bypass, dj's fuel + regulated fuel return, sct by eric, 4in silverline no cat, isspro gauges, cat elc coolant, hids, lots of other odds and ends......
scotty2280 is offline
post #2 of 8 Old 11-22-2011, 05:17 PM
BOGGERBOYS's Avatar
becareful what battery and alt amprage you run together you could blow the batteries up but try these links nations is expensive & pertty but there sopose to be the best? the quality link is the best bang 4 the buck make sure you know what your alt is puttin out now and what your draw needs to be i wouldnt go higher than like a 200 amp that might even be to much, hope the links help?!
High output alternators, high torque starters, Ody
Nation Starter & Alternator,Tractor Auto,Marine,Truck,Small Engine
High Output Alternator, 200-250-300-350 Amp Alternators, high output alternators, GM,Ford, Chrysler Dodge Alternators
BOGGERBOYS is offline
post #3 of 8 Old 11-22-2011, 05:30 PM Thread Starter
scotty2280's Avatar
ive been doing alot of reading and never heard of anyone blowing them up. i know i need to upgrade my cables to 2/0 and fuse it. i was planning on going with a 200 amp. thanks for the reply.
post #4 of 8 Old 11-23-2011, 08:54 AM
Snake's Avatar
Quoted: 47 Post(s)
After a lot of research, I bought a 200a from alternatorparts.com and highly recommend them.
Snake is offline
post #5 of 8 Old 11-23-2011, 01:28 PM Thread Starter
scotty2280's Avatar
thanks snake. did you upgrade your wires to? did u make them?
post #6 of 8 Old 11-23-2011, 02:19 PM
Snake's Avatar
Quoted: 47 Post(s)
I didn't upgrade any of my ground wires, but I did add another cable between the batteries and upgraded the wire from my alt to my passenger side battery. I made my own and bought everything from NAPA.
Snake is offline
post #7 of 8 Old 11-23-2011, 10:19 PM Thread Starter
scotty2280's Avatar
i was wondering if upgrading the grounds mattered as much. how long have u been running ur setup?
post #8 of 8 Old 11-24-2011, 09:30 AM
Snake's Avatar
Quoted: 47 Post(s)
Probably coming up on 2 years now, and I have definitely put it through its paces.
Snake is offline
