Overhead trip computer - Ford Powerstroke Diesel Forum
Old 11-19-2011, 09:11 AM
The trip computer on my 2005 Excursion is not turning on anymore. Have been looking for the fuse, but don't know which one it is. Somebody can help me.
Thanks,
Marcel
pbclodge@gmail.com
Old 11-19-2011, 06:13 PM
Are you sure it's a fuse? Mine stopped working because the actual board failed. I sent it out for $30 to get fixed. If it has been getting dim then chances are it failed.
Old 11-19-2011, 09:02 PM
This is very common and is an easy fix. Usually it's the resisters that come loose. I had mine stop working and when I removed it found there were 2 resisters that came loose. A little soldering fixes it. Check the other soldiers while your there and you should be set. Mines been working for the last 4 years with no other issues.
Old 12-05-2011, 09:59 AM
overhead trip computer
How do you emove it guys?
Old 12-05-2011, 10:16 AM
It pops off. No screw holding it in. Once removed there are screws to remove it from the unit. But to get it off it only held on by clips.
Old 12-05-2011, 10:19 AM
For a write on the fix, take a look here:
Overhead computer Fix - Easy and it works
