PIE adapter in a 2007? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 11-11-2011, 09:03 AM Thread Starter
trophy_23's Avatar
Every where I look I see that the PIE or PAC modules are only for use on 1999-2006. What are my options on a 2007 6-disc w/ aux button? Hopefully someone around has done it, I don't want to order the wrong thing and I don't want to tear the dash apart until its time to install unless I have to.
2007 F350 SC FX4 Lariat
Edge Insight CS w/ Pillar Mount & EGT
SCT with Gearhead Tunes
ARP Studs & EGR Delete
High Idle
Duraflaps
Back Rack & Tool Box
LED bed & toolbox Lighting
4 Hella's Behind the Grille
18W LED Hitch-mount Back-up Lights
Dually ID Bar
**You could be the one match to save a life!!**
trophy_23 is offline
post #2 of 11 Old 11-13-2011, 08:51 AM Thread Starter
trophy_23's Avatar
No one with an 07' has done this?
High Idle
Duraflaps
Dually ID Bar
post #3 of 11 Old 11-15-2011, 05:16 AM
hawkeyediesel's Avatar
I've had my eye on this for a while, but just haven't pulled the trigger yet.
Direct Connect 4.0 iPod Adapter for Vehicles Without Factory Satellite Radio IPDCFD004N - Direct Connect - Phone/iPod Integration
Seems like a really neat product, but it seems to be specifically designed for the IPod, so it may not be what you are looking for. It does say that it works in an 07. Let me know if you use it and if it is worth the money.
2006 F-250 Lariat Crew Cab | 6.0L | 4x4 Auto w/ 3.73 | ~100,000 miles | AstroStart Remote Start | LineX Spray-On Bedliner
Turnover Ball Gooseneck Hitch | Scangauge II w/ homemade mirror mount | Glow Shift Fuel Pressure Gauge | Glowshift EGT Gauge
Dieselsite Coolant Filter | CAT Delete Pipe | SCT Livewire tuned by Innovative Diesel | River City Diesel EGR Delete | Blue Spring Upgrade | High Idle Mod | ARP Studs
2009 30ft Puma Travel Trailer | Approx 8000lbs when loaded up for the weekend!!
hawkeyediesel is offline
post #4 of 11 Old 11-16-2011, 07:32 AM Thread Starter
trophy_23's Avatar
Thanks for the info. I'll keep that in mind, still wondering about the PIE also.
High Idle
Duraflaps
Dually ID Bar
post #5 of 11 Old 11-16-2011, 09:37 AM
contact the place that you are planning on buying from. They should give you the correct info. I have one on my 06. I would think that the same one for the 06 would be the same for the 07.
topncc is offline
post #6 of 11 Old 11-16-2011, 09:38 AM
Another thought. Contact Crutchfield. If anyone can give the correct info it would be them.
topncc is offline
post #7 of 11 Old 01-16-2012, 08:18 PM
JesseKK's Avatar
Quoted: 33 Post(s)
Garage
my 07 has one that says it for an 06. it works just fine
JesseKFK
2007 F250 XLT CC 6.0 PowerStroke FX4 R.I.P. 3.6.16
Livewire TS LOoNeY
Studded
BPD 58v FICM
BPD Oil&Egr Cooler
Glow Shift Pyro,Fuel
High Idle Mod UF#4
Fog Light Mod
Harpoon Mod
Dome Override Mod
6000k Bi-neon Hids
Sinister Coolant Filter
8in Rize Ind 4 link
35" Mickeys on 20s
Blue Leds
Power Service Every Fill Up
ATV 2008 Yamaha Raptor 700 FI
KCCO
Originally Posted by Karls03 View Post
I hate Edge power products so much, I quit using Edge shaving gel
JesseKK is offline
post #8 of 11 Old 01-16-2012, 10:55 PM Thread Starter
trophy_23's Avatar
Perfect, I finally got one, but I haven't had time to put it in yet.
High Idle
Duraflaps
Dually ID Bar
post #9 of 11 Old 01-29-2012, 11:52 PM
I was wondering the same thing. I also have a 6cd changer and I would like to use a thumb drive. Did this work for you? If so where did you buy it from?
Thanks
2007 F-350 4x4 Outlaw
edge juice w/ attitude
MBRP 4" exhaust
6" fabtech on 37" MTs
1983 Porsche 944
white 5-speed
1979 mustang cobra
4.6 32V teksid
road racer/ street car
2001 GSX-R 1000
7t9cobra is offline
post #10 of 11 Old 01-30-2012, 12:31 AM
HaysKSFirefighter's Avatar
I have one in my 07 with 6 disk and it works just fine. Bought mine from amazon.com
Tornado Alley PowerStrokers Director
2007 F-350 CCLB XLT FX4 ZF6 08 Mirrors, CTS, Gearhead, BD EGR Delete, Coolant filter, B&W, Custom rear springs, still rockin the stock head bolts and clutch!
HaysKSFirefighter is offline
