Ghost in truck - Ford Powerstroke Diesel Forum
Old 11-08-2011, 12:17 PM
Ghost in truck
I have a 2003 F250 super duty xlt fx4. After the truck is shut off and the key removed from the ignition, sometimes the Interior Lights will flash, Locks will lock and unlock, radio will come on all by itself. I'm not sure what the problem is and need a little help. I thought it might be the ignition but when I shake the ignition switch while it is acting up it doesnt do anything to stop it. I checked the delayed accesories relay but it is working as advertised. Also if you open the door while it is acting funny it stops. Not sure what else to check.
Old 11-08-2011, 12:43 PM
Is there a remote start or aftermarket alarm or anything on the truck? I'm not real good with electrical gremlins but those are the first things that come to mind.
2006 F250 Lariat FX4:
MBRP 4" Turbo Back Exhaust
Blue FPR Spring
Edge Insight CTS
1200rpm High Idle Mod
Dieselsite Coolant Filter
58v Swamps FICM
SCT w/ Matt's SRL Tune
Old 11-08-2011, 01:28 PM
Send a message via MSN to Jesse.James
I know some Ford radios are known for adjusting the volume on their own.
Old 11-09-2011, 05:03 AM
The only thing aftermarket in the truck is the Edge chip. I also heard that the body control module can do this and unlike the ecm module the bcm module does send anything to the check engine light.
Old 11-18-2011, 09:35 AM
Call a priest with exorcism experience
Old 01-10-2012, 09:34 AM
additional info
replaced lock cylinder in steering column still doing the same problem. not sure what else to do
