UPFITTER SWITCHES???? - Ford Powerstroke Diesel Forum
Old 10-31-2011, 06:00 PM
Alright , so im tryin to hook up some stuff to my upfitter switches, there is power at the switches, i can hear the relays in the box above the glove box doin their thing, the fuses are good but i have no power at the wires themselves . Has anyone else had this problem? Does anyone have any idea what it is im missing? Any ideas would be greatly appreciated.
Old 11-04-2011, 09:48 AM
Maybe you are at the wrong wires? The wires for the switches are just behind the fuse panel. There are other unterminated wires that go through a grommet in the firewall, close to same location.
Adam
Old 11-04-2011, 10:39 AM
Do a google search..there are a bunch of threads explaining the location and which color wires go to which switch. Remove the 4 bolts to the fuse panel and the wires are behind that.
Old 11-04-2011, 10:42 AM
Directions:
Remove all rings, watches, & bracelets (a must when doing electronics)
Remove the drivers side access panel (below the steering wheel)
Using the 11mm socket & ratchet, remove the 4 bolts which hold the fuse panel. Gently, pull the fuse box through the opening and leave it hang.
Look for the UpFitter wire bundle as noted in this photo:
Choose which switch you want to use. Here is a list of wires:
Aux-1 Circuit No 1936 wire color: Orange/Lt. Green [30amp]
Aux-2 Circuit No 1933 wire color: Orange [30amp]
Aux-3 Circuit No 1934 wire color: Orange/Yellow [10amp]
Aux-4 Circuit No 1935 wire color: Orange/Lt. Blue [10amp]
Here you go..
Old 11-04-2011, 03:28 PM
NOT a Democrat
Good info nove!!
89 Mustang, nice avitar. I have a 93 notch (coral reef blue)
Old 11-08-2011, 03:37 PM
Feedback Score: 5 reviews
2005 Ford F250 Project Truck
http://search.yahoo.com/r/_ylt=A0oGd...20Switches.pdf
http://search.yahoo.com/r/_ylt=A0oGd...-html/Q117.pdf
Old 11-08-2011, 06:34 PM
Thanks. I've had several. The one in my avatar was an 88 coupe. It's been about 10 years since I had that one.
Adam
