06 Stereo removal - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-21-2011, 11:22 PM Thread Starter
06 Stereo removal
Tried the ever popular search function but yielded no results. My question is how to remove the stock double DIN unit from my 06. Anyone know how?
03 F-350 FX4 SC LB 8" BDS lift, 18" Fuel Hostages, 37" Mickey Thompson MTZ's, ARP Studs, NADP EGR delete, AFE Intake, CFM + Large Bore manifold, MBRP 4" turbo back with 6" Black miter stacks, SCT TSX with tunes from Gearhead and Quick Tricks, Bulletproof bumpers.
GForce is offline
post #2 of 4 Old 10-22-2011, 12:45 AM
You'll need to pull the dash trim, which is fairly easy to do. Getting it off around the steering wheel is the tricky part.
2006 Ford F-250 Crew Cab 4wd XLT 6.0 Powerstroke Diesel
  • Rev-X Oil Additive and Archoil AR9100 Reviews(Check out my videos:
losbanosf250 is offline
post #3 of 4 Old 10-22-2011, 05:55 AM
RRF985's Avatar
I put the truck in First (1), make sure the parking brake is set obviously. Pull the whole dash trim out towards you, then kinda work it over the shifter. You're going to want to unplug the headlight switch and if you have it, the switch for the power pedals. This will give you a bit more working room as those wires don't have a lot of excess to them. After that you should have plenty of access to the radio. There are 4 bolts that you will need to remove to get it out. After that disconnect the wires and it's out. Good luck!
2013 Ford Fusion Titanium AWD, Deep Impact Blue
Totaled 12-26-12 It will be missed.
2006 F-250SD Lariat CCSB Dark Stone
-ARP head studs
-SCT SF3 w/ SRL+
-BPD Semi-bullet proof kit
-BPD FICM
-High Idle
-Edge Insight CS w/ EGT
-GlowShift Fuel Pressure gauge
-285/70/17 Toyo Open-Country A/T
-4" MBRP Turbo-back w/ cat-delete
-Randy Ellis bar w/ Hella 500s
RRF985 is offline
post #4 of 4 Old 10-22-2011, 07:59 AM Thread Starter
Got it. Feel kinda stupid now, cause that was pretty easy.
GForce is offline
