I want my radio to turn off with the key. - Ford Powerstroke Diesel Forum
Old 10-17-2011, 12:24 PM
I want my radio, windows, and whatnot to turn off when I turn the key off rather than when I open the door. Is there a way to do this?
Old 10-17-2011, 05:56 PM
information regurgitator
Sure. Every time you turn the key off, open and close the door.
Old 10-17-2011, 05:59 PM
Thanks lol. I would like it to go off when the ignition is shut off because of the turbo timer. If the turbo timer shuts the truck off the radio will stay on for 10 minutes since there's no one around to open the door haha.
So far it hasn't had any negative effects but still, I'd rather it just turn off when the truck shuts down.
Old 10-17-2011, 06:05 PM
Feedback Score: 7 reviews
You could turn the radio off before you get out of the truck.
Old 10-17-2011, 06:09 PM
I could, but I'd rather it turn itself off haha.
Old 10-17-2011, 06:41 PM
You could run a new 12V wire to the radio that loses power when the key is off.
Old 10-17-2011, 06:49 PM
I could go for something like that.
Does anyone happen to know which wire supplies power to the radio until the door is opened?
Old 10-17-2011, 06:55 PM
Found this on the web. I think you would want to replace the light green/pink wire but it would be worth checking with a volt meter first.
2005 Ford F250 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Light Green/Pink
Car Radio Accessory Switched 12v+ Wire: Black/Violet
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Blue
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Light Blue/White
Left Front Speaker Negative Wire (-): Orange/Light Green
Right Front Speaker Positive Wire (+): Dark Green
Right Front Speaker Negative Wire (-): White/Light Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Tan/Yellow
Left Rear Speaker Negative Wire (-): Gray/Light Blue
Right Rear Speaker Positive Wire (+): Brown/Pink
Right Rear Speaker Negative Wire (-): Orange/Red
Old 10-17-2011, 06:59 PM
From my car stereo wiring experiance my guess would be that it must be the Black/Violet wire. The constant should never turn off, since it supplies power to keep your presets and clock memory.
I will check into it though, I would need to find a switched power source that doesn't rely on the door opening to cut power.
Thanks for the info on the wires.
Old 10-17-2011, 07:01 PM
Your right it would be the switched power wire.
