| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
steering wheel control audio wires ??
does anyone know the location of the audio steering wheel control wires / i have an aftermarket 2 din touchscreen head and it has 3wires for this key1 ,key2 wire and ground wire for the steering wheel controls,but i cant figure out where they should hook up to on my truck ? oh yes 2005 f-350 powerstroke srw 4x4 lariat.
I dont know, i have an aftermarket deck as well and my steering wheel controls dont work. I was told i needed an adapter to make them work. The adapter was about a 100.00 bucks.
The aftermarket control adapter is only like $38. Here is a link to it:
Metra's website has full instructions on how to install it and which wire it is. I believe it was wire #18 in the harness. You can also get this harness for a few bucks which makes hookup real easy. This way you don't have to do a thing to your factory harness. Hook the wires from the aftermarket radio to this harness as well as the wires (3 of them) from the Metra adapter and it's plug and play. Keep in mind different aftermarket radio's have different connections for steering wheel controls. Mine had a 1/8" mini plug. Others are different. Steve |
If you go to this website you can enter your vehicle info and it gives you instructions.
Axxess Interface Steve |
4x4ff, thanks for the info. I will check it out...
On my 07 it is the lite blue with red tracer in Pin 18 on the factory harness.
I have the axxess self programming that I still have to wire in and it plugs into back of the stereo with a headphone like jack. 3 wires, switched power, ground, and blue/red wire. Dik |
