| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
CAB LIGHT WIRING HELP! ASAP
So i ordered recon smoked cab lights. got them on. mounted. wired. everything. but i can't find out where to plug my power wire into. ive been reading and reading about a new harness and pluggin it in down by the pass side kick panel...
no i am not getting a new harness or buying anything. where can i tie my cab light power wire into? what wire can i take it to in the switch? i can't find a wire diagram to save my @$$. and no, i am not hooking my cab lights up to a seperate switch. they are going to turn on when i turn on my lights, automatically. thanx a heada time! |
Just wire it to your parking lights(brown wire @ the headlight switch). Make sure you fuse it though.
thanx! i could just put a butt connector in that brown wire, take one wire to go to the switch, and two wires twisted together on the other side of the connector: one going where that wire normally goes (parking lights), and another wire going a few inches into a fuse link then to my cab lights ey?
I recommend soldering the wire in especially when splicing but to each there own.
Sent from my DROIDX using AutoGuide App |
Yeah, i recommend solding to the wire instead of cutting it then crimpimg a butt connector on it. Solder it then cover it with a heatshrink tube or wrap electrical tape on it real tight, then put a ziptie on top of the solder. That way when the e-tape eventually fails from heat, the ziptie will keep it on there for a long time.
