| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Help....building a box for 4 - 10's
As the title states I'm needing some help building a box for 4 RE REX 10's. For the rear seat I will be moving/removing the power window motor, rear carpet, jack mount, vents, and all else that needs to go.
For external dimensions I have: Length: 58 Height: 16 1/4 Top depth: 3 3/4 Bottom depth: 6 1/4 With the dimensions I have listed above get me in the ball park to fit behind the back seat? I also will be running speaker grills to avoid the subs hitting the seat. I've seen a few companies out there that sell the 3 - 10's box but nothing for 4. I'm a metal man myself(welding, sheet metal work, etc.) and if I could build it out of 1/4 plate that would rule, but my carpentry skills are not the best............so I'm either looking to buy or have someone near central IL help/build me one.(beer & food provided) Can anyone help me out? |
length-60
height-17 top depth-3.5 bottom depth-6.5 use mdf 3/4" and you won't need bracing inside with that thickness. use the grills to protect the subs and you will be good to go. Don't use metal to make any kind of speaker box. The what are the specifications on those subs what kind of air space do they require, I couldn't find that info. |
a metal box would sound horrible
Thanks for the help all. I won't be building the box in a steel medium as wood is much cheaper.
Subs specs: Mounting Depth - 5 inch Mounting Hole Diameter - 9.3 inch Overall Diameter - 10.9 inch Bolt Hole Circle - 10.5 inch Motor Width - 4.875 inch Motor Depth - 1.9 inch Basket Depth - 3 inch Displacement - 0.09 cu. ft. Weight - 6.8 lbs. ~~~~~~ T/S Parameters: Electrical Q Value -Qes: 0.39 Mechanical Q Value -Qms: 4.37 Total Speaker Q Value -Qts: 0.36 Free Air Resonance -Fs: 21.5 Hz Equivalent Compliance -Vas: 75.6 liters One-Way, Linear Excursion -Xmax: 12 mm Efficiency -SPL 1W/1m: 84.7 dB SPL Effective Piston Area -Sd: 322 cm^2 DC Resistance -Re: 3.2 ohm Nominal Impedance -Znom: Dual ohm Thermal Power Handling -Pe: 175 W Force Factor -Bl: 15.4 Sub box size: Compact .35 Optimal: .50 |
will u put pics up of the box u make?? i acutally have 4 10s in the back of my truck but their all in single boxes.. i have the plastic ripped out in the back of mine.. and i was wondering if u were gonna take ur plastic out or not.. if so.. what r u going to do bout the air vents??
What air space do they require? I have about 2.2 cubic feet of air space for my 4 tens with poly it sounds pretty good I can take a couple pics tomorrow
According to RE they take anywhere from .35 to .5 cubic feet, so I hope they should be good to go. |
that should come out pretty good then. you will have to remove the vents and put dynamat over the openings and it should fit good.
can you get dynamat in stores??
yeah or ebay I used the butyl fatmat
