| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Seatbelt alarm
Hello,
How do I shut the seatbelt alarm off? The truck in question is an 03 F250. Thank you |
Wear it!
Sorry, couldn't resist. Here: Belt Minder Deactivating/Activating Preparation Before deactivating/activating the belt minder, apply the parking brake. Place the gearshift in the PARK position (automatic transmission) or the NEUTRAL position (manual transmission). Place the ignition switch in the OFF position. Close all the vehicle doors. Unbuckle the driver safety belt. Place the headlamp switch in the OFF position. Deactivating/Activating Turn the ignition switch to the RUN position. (Do not start the engine.) Wait until the safety belt warning indicator turns off (approximately 1 minute). NOTE: Step 3 must be completed within 60 seconds after the safety belt warning indicator turns off. After this step the safety belt warning indicator illuminates for 3 seconds. Buckle and unbuckle the safety belt 9 times, ending with the safety belt unbuckled. NOTE: Carry out this step within 10 seconds after the safety belt warning indicator is illuminated. Buckle and unbuckle the safety belt. The following sequence of events confirm the belt minder is enabled: flashing of the safety belt warning indicator 4 times per second for 3 seconds 3 seconds with the safety belt warning indicator off flashing the safety belt warning indicator 4 times per second for 3 seconds again The safety belt warning indicator flashing 4 times per second for 3 seconds provides confirmation of belt minder disabled. After confirmation, the deactivation/activation procedure is complete. |
will this also work for an 07?
I believe so. Give it a try.
I have an '05 Ex and every friggin time I take my truck in for servicing the dealer turns my seatbelt warning back on. It is against the law up here not to wear seat belts but the next time they turn my warning chime back on I'm going to go postal.
Simplified:
Belt Minder Deactivating Preparation "Before deactivating the belt minder, apply the parking brake. Place the gearshift in the PARK position (automatic transmission) or the NEUTRAL position (manual transmission). Place the ignition switch in the OFF position. Close all the vehicle doors. Unbuckle the driver safety belt. Place the headlamp switch in the OFF position. Turn the ignition switch to the RUN position. (Do not start the engine.) Wait until the safety belt warning indicator turns off (approximately 1 minute). Buckle and unbuckle the safety belt 9 times, ending with the safety belt unbuckled. After this step the safety belt warning indicator illuminates for 3 seconds." You should be good to go. |
Seems strange, but after I did this, it also stopped doing that annoying thing where the drivers door unlocks itself after hitting the lock button. Are the 2 tied in together or am I just losing my mind?
i did this on my 04 and it worked great thanks.
I just unplugged the connector at bottom back of the drivers seat on my 03.
