Remote Batteries? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-03-2011, 12:14 PM Thread Starter
Remote Batteries?
Pros and cons of doing this? looking for more room for coolant filter, oil filter.
speops38 is offline
post #2 of 5 Old 05-28-2011, 08:00 PM
Make sure you use the largest welding cable or better yet a UL listed battery cable you can afford. You are looking for cables the size of your thumb. The idea here is to keep the voltage drop under load to as low a value as you can. Even 1 volt of drop will cause higher starter currents also remember low voltage KILLS the FICM in these trucks.
HAM_RADIO_MAN is offline
post #3 of 5 Old 10-28-2011, 09:34 PM
Rblprd's Avatar
Frame mounted battery box
For the frame mounted AUX battery on the V10 and 6.0l E20/E350 here is a parts list (frame should already have the holes in it for the box)
All these are factory part numbers (got them from partsguyed.com)
Battery Tray Assembly
4C2Z10A687AA
6C2Z10756A
E7TZ10718B
4C2Z10769AA
N808992S301 X2
N605920S439 X4
N605907S440 X4
05' F350 CC LB SRW FX4 King Ranch
Diablo Trinity Tuner, Glowshift 3 in 1 EGT/Boost/Tranny Temp gauge.
Am lovin the 6.0L
After all, how often can ya push 8500 pounds of truck to 110 MPH in stock trim
Rblprd is offline
post #4 of 5 Old 10-28-2011, 10:23 PM
Quoted: 5 Post(s)
I thought of doing that when i redid my electrical, but I decided against it.
I would rather relocate the accessories I wanted than relocate the batteries.
These trucks draw some serious amperage at cold start with GP's on and starter going. I would be concerned with voltage loss as stated above.
There is someone here who went to two optima red tops and relocated both to one side IIRC.....
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #5 of 5 Old 10-28-2011, 10:34 PM
Rblprd's Avatar
I was thinking of adding a 3rd battery to mine actually. use it for my HAM radio gear and such, with an ignition switched solaniod to disconnect it when the ignition was off (had a similar setup on my Jeep when I owned it)
would likely order a 00 cable for it when ordering my 00 battery cables. Just to avoid voltage loss
Am lovin the 6.0L
Rblprd is offline
