| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Rear Sliding Window Broke
Hey Guys - Did a quick forum search but no luck...
Went to open the rear sliding window yesterday and it stopped halfway open. CHeck the fueses (or what I thought were the fuses) and no luck. I was able to manually push it closed... Any ideas of what it could be? Thanks! |
motor.......?
Mine's been broke since the day I got my truck (used) and it was the cable. Getting access to the motor and the cables isn't too terribly difficult and I'd check to see if they're still intact.
Cables I'd say ....
Visit your Ford Dealer & tell 'um you need a 6C3Z-7823394-AA ... they'll want your old cable 'n motor as a core. |
yeah same thing happened to me i took it to the dealer and they fixed it under my extended warrenty along with the passenger side window motor it cost like 1600,00 dollors
Sometimes the track is dirty, I need to clean mine and see if works
thanks guys! will try cleaning first!
just tilt the back seat up and check to see if the regulator is working. Should be easy enough to see. The motor is bolted to the pass. rear right below the window.
