| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
Quad Fogs with up-fitter switches..possible?
Alright, so I want to do the quad fogs..
Would it be possible to hook them up with the up-fitter switches? If so, how? I have looked everywhere for a thread, but no luck. Thanks in advance!! |
Yea , the wires for the upfitter switches are under the dash and there are pass through wires that go through the fire wall . The upfitter wires are under the dash by your right knee (kinda) . They are labeled .
yes you can do it, but the wires for the uplifters are up behind the fuse box. you can pull the acess pannel down under the steering column and remove the bolts that hold the fuse box. slightly pull it down and you will see them. they are labeled and already HOT form the factory. I have my fogs in my bumper hooked up to #3 and #4
Thats where they are on My 06, I figure his are in the same place
Thanks!
So I can just run the foglight wire straight into the upfitter #1 wire and be good to go? |
I believe #1 is a 30 amp fuse thats why I used 3 & 4, but yes #1 will work
Alright thanks sounds easy enough,
and yea mine are on the left side by the Parking brake. |
2 of the switches are 10 amp and the other 2 are 30 IIRC. 10 amp is fine if you use a relay near the lights
Here you go.
Switches Circuit Color Fuse Aux 1 1936 Orange/Light Green 30 Amp Aux 2 1933 Orange 30 Amp Aux 3 1934 Orange/Yellow 10 Amp Aux 4 1935 Orange/Light Blue 10 Amp |
