HID's stuck on brights - Ford Powerstroke Diesel Forum
post #1 of 26 Old 04-19-2011, 09:40 AM Thread Starter
Vip
I just purchased a used '04 F350 last week. It has HIDs installed in it which is fine but when they are on they are stuck on brights. I wouldn't think this is usual on HIDs but this is the first set I've had any experience with. The dash light symbol is on but not as bright, then when you switch to brights the symbol becomes brighter but nothing changes in the light pattern in the headlights. Any suggestions on what to check? I have not investegated the current wiring - before checking for stuck relays I thought I'd check on here for any help.
Thanks.
Early 1999 F-250 PSD SCLB
4" Turbo back - DIY 6637
Vip is offline
post #2 of 26 Old 04-19-2011, 10:01 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
Thanks.
I would start by checking the grounds for the ballasts.
dhanna6powerstroke is offline
post #3 of 26 Old 04-19-2011, 10:15 AM Thread Starter
Vip
I'll report findings tonight when I get home assuming this storm moves out.
Should the ballast be ran to battery ground or is chassis ground good enough?
Vip is offline
post #4 of 26 Old 04-19-2011, 10:17 AM
dereku's Avatar
Feedback Score: 7 reviews
Send a message via AIM to dereku
Never run anything to the battery ground. It has to be a chassis ground to filter out the fluctuations in voltage.
What brand are these? And what happens when you flash the brights?
2002 f250 BFT Edition
dereku is offline
post #5 of 26 Old 04-19-2011, 10:22 AM
Mod Newbie
Quoted: 19 Post(s)
Definately chassis ground.
post #6 of 26 Old 04-19-2011, 10:23 AM
Mod Newbie
Quoted: 19 Post(s)
I don't think he knows since they were installed before he bought the truck.
post #7 of 26 Old 04-19-2011, 10:24 AM
dereku's Avatar
ahh maybe I need to read better than skim over. But any markings or stuff on the bulbs or ballasts that will give it away?
Are these a plug n play style or are they spliced in?
dereku is offline
post #8 of 26 Old 04-19-2011, 10:24 AM Thread Starter
Vip
That's what I figured but wanted to make sure.
Nothing happens when flashing the brights.
Vip is offline
post #9 of 26 Old 04-19-2011, 10:25 AM
Mod Newbie
Quoted: 19 Post(s)
Mine are from DDM and there are no markings on them anywhere to indicate the brand. Not sure why either.
post #10 of 26 Old 04-19-2011, 10:25 AM Thread Starter
Vip
I haven't given them much look but will after work and report back on brand. From a quick glance, look to be plug and play.
Vip is offline
