fog light mod - Ford Powerstroke Diesel Forum
Old 04-09-2011, 10:16 PM
fog light mod
I have seen a thread on her about how to mod the fogs so they stay on when you turn on the high beams, now i cant seem to find it can any one help? thanks
Old 04-09-2011, 10:39 PM
back to business
Here's a link
S&S Diversified: Prototype CAD CAM Design Fabrication Machining Technical - Northeast NY NJ CT PA NYC
Old 04-20-2011, 06:02 PM
I did it with just a simple relay
get a 40 amp SPST (single pole single throw) relay it will have (4) terminals.
each terminal will have a number molded or printed on the case.
numbers will be 30, 85, 86, 87, and sometimes 87A
# 86 goes to ground
# 85 goes the high beam wire
# 86 goes to 12v+ use a fuse!
# 87 ties into the fog light lamp + wire.
The best part of doin it this way, the fogs come on with the high beams regatrdless if they are turned on or not.
If your vehicle inspections require the fogs to go out when high beams are on just put a swithch or plug in the #86 wire to ground and they will pass inspection.
as with any mod procede at your own risk
Old 03-28-2012, 06:31 AM
# 86 goes to ground
Something does not seem right with this mod.....2 wires are connected to #86 on relay.
Should #30 go to positive
Old 03-28-2012, 06:48 AM
You don't need a relay. You simply pull the fuse box out cut the wire (sorry don't remember which one) in the harness next to the connector and ground it.
Done. Yes sir. Works fine.
Shawn
Old 03-28-2012, 08:33 PM
Fog Light OverRide
Old 04-02-2012, 12:20 PM
Feedback Score: 3 reviews
Just pulled green wire with black tracer, cut on fuse box side and grounded. Viola
Old 04-02-2012, 12:28 PM
Feedback Score: 5 reviews
tagged
