block heater is melting extension cord plug - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-22-2011, 08:46 PM Thread Starter
Recently I noticed that my block heater plug is melting the extension plug on one prong. I tried 2 extensions with the same results. What could be causing this and how do I trouble shoot the problem?
2006 F-350 Diesel, 4x4, crew cab, short box, single rear wheel
SnoSheriff is offline
post #2 of 8 Old 03-22-2011, 09:12 PM
Is it a good quality heavy gauge cord?
1991 Ranger - 38" TSL's, 3 link, One tons, 5.38s on King air shocks....under construction.
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 31x10.50r15 MT's.
2008 F350 - Crewcab short bed, 6.4L diesel, H&S XRT Pro, AFE DOC/DPF delete
1972 Mustang Coupe - 302, c4, 9", 4.11's locked.
WildStyle is offline
post #3 of 8 Old 03-24-2011, 05:30 PM Thread Starter
Um, no I don't think it's a heavy duty type cord. I used this cord all winter and only recently noticed the problem
post #4 of 8 Old 03-25-2011, 11:35 AM
You need a heavy extension cord, which will have better contacts in the plug. These block heaters are something like 1500 watts, which is over 10A current draw.
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline
post #5 of 8 Old 03-25-2011, 08:43 PM Thread Starter
Ok, I got a 14/3 extension cord rated for 15Amps and I will try it this weekend.
Is there a way to test the block heater before I ruin the new extension cord? I do have a multimeter... Can I test the resistance or something to see if it's defective?
post #6 of 8 Old 03-25-2011, 08:54 PM
It won't pull more current if it's bad, only less or none. The new cord should fix things.
post #7 of 8 Old 03-31-2011, 04:31 AM
shiprek's Avatar
If you have a clamp on ampmeter you can use this to determine what amperage you are drawing. For example, a 1500 watt heater should pull approximately 12.5 amps +/-. The resistance of your heater should read roughly 9.6 ohms depending on its age and condition. A 14/3 extension cord is close to the maximum allowable current (15 amps max.). If you are dealing with a very long extension cord you also have to deal with voltage drop will will cause more current draw and possibly melt your extension cord. If you have not tripped a breaker (or blown a fuse) on your household circuit I suspect you extension cord is too small (wire size) or too long (50-100 feet?) If this is also being used outdoors/in a garage it should be on a GFCI. Hope this helps.
2004 F250 Lariat/6.0L/SRW/Crewcab/Shortbed FX4
EDGE Evolution CTS
Python 424 Remote Start
Volant Ram Air
RCD-EGR Delete
Cat/Muffler Delete
Rancho RS 5000 Shocks
6.4 Banjo Bolts
Throttle Plate Delete
4" Straight Pipe
Updated to "Blue" Fuel Pressure Spring
DIY Coolant Filter
Caterpillar EC-1 "RED"
"Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin, 1759
shiprek is offline
post #8 of 8 Old 03-31-2011, 06:45 AM
A few clarifications. First, a clamp on amp meter would need to be clamped around only one wire in the extension cord, either the positive or neutral, but not the ground. If you clamp it around the entire extension cord, it will read zero as the current in the positive and neutral will cancel each other out to the meter. Second, since the heater is a resistive element, additional resistance and voltage drop in the extension cord will lower the total current being drawn.
