| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
NO Parking Lights!
This is more of a rant, than a cry for help. So i installed some digital HID's from retro-solutions a little over a week ago. It is raining today and i turn my parking lights on when i'm pulling out of my driveway this morning, then i realize when i pull into my work parking lot that the dash lights are dark. Low and behold the parking lights no longer work. I'm assuming that the plug i left "unplugged" got wet and caused a short or something or somehow the fuse just blew.
I plan on taking a look at it when i go to lunch here shortly, so i'll let you know what has happened. But thats my stupid rant for the day, usually its something small like a fuse so i'm hoping something major has not happened. |
so after checking i dont see any blown fuses, now i'm at a loss...
i'm looking in the book and i see trailer tow park lamps, however not just "park lamps". I noticed that there are exterior lamps, which that fuse is not blown, the trailer tow park lamps is not blown, also i see there are back up lamps and trailer tow back up lamps. So there has to be just a "park lamps" right? can someone help me out with the correct fuse? |
Sorry, bud. I don't know which fuse to check. I do have a question - What connection did you leave unplugged? I'm assuming you did it on purpose because you said you knew that you left a connector unplugged. I know when I installed HID's into my RZR, I had to upgrade the fuse due to the initial draw when turning them on, but this doesn't sound even remotely the same.
i've done some reading and it is fuse #17 which is the exterior lights fuse. It looked fine but maybe i was looking at the wrong one... or, i've had a problem before where the fuse looked fine, but once i replaced it everything worked again so i'm gonna work on it some more when i get home.
the HID's work by only plugging into one side of your headlight connectors, for example i put all my wiring on the passenger side of the truck and used the passenger side headlight plug. The drivers side headlight plug is no longer used, because you're running your wire from the harness to the 2nd ballast on the drivers side. I was thinking that may have gotten wet however i know that is not the issue since that has no bearing on the parking lamps what so ever. |
Interesting. Doesn't that seem a little bit weird to you? It could function perfectly well, but that strikes me as odd. Anyway, I sure hope this fixes it for you.
it is odd if you're not aware of how the HID's are wired up. the HID's come with a plug and play harness with all new connections, relays, power etc. It only uses the oem headlight plug to as a switch, to tell the new HID relay's when to come on and power the ballast, as well as when to flash the brights. It does not take any power at all from the old headlight harness.
Does anyone else have any ideas about my parking lights? |
found the culprit, fuse #17 is the correct fuse. its labeled as exterior lights in the user manual. its a 15A fuse. Replaced it and it popped again seconds later.
ended up pulling all the cab lights, and tail lights, only to find a burning plastic smell coming from the rear of the truck. i forgot all about the license plate lights. The drivers side license plate light socket had shorted and was burning/melting away. So i cut it off for now and tucked the wires up by the frame. Now off to find a new socket to tie into the wiring to replace it... |
Interesting. So I'm guessing you wire them up to the batteries directly. I guess it doesn't matter now since you figured out the issue. Glad you found the problem and it was simple to fix.
Then the harness has a set of longer wires in which i ran in front of the radiator to the other side of the truck to the other headlight, the ballast for that side plugs into the harness as well as you need a ground. It confused me when i first looked at it, however it makes sense because you would need two large harnesses if it didn't wire this way. At first i didnt like having one headlight plug just dangling but last night i wrapped it up in a small zip lock back and zip tied it tight so there is no chance of water getting to it at all. But it makes sense, because like i said the HID's are not getting their power from the OEM headlight plug, they're just using that as a trigger to know when the headlights come on as well as when to flip on the high beams. If i can find a drawing of the harness i'll post it up so you get a better idea, i feel like i'm just rambling here... lol |
Thanks. I think I get it now, but a diagram might help.
