how to bypass EMG park feature for dvd while driving - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-13-2011, 06:02 AM Thread Starter
knostroke's Avatar
Feedback Score: 10 reviews
i bought a pioneer 3200 dvd player head unit and it wkont let you play dvd unless the emergency brake is pressed? anyway to bypass it?/
2004 FX4 CC w/zf6 ! <><
knostroke is offline
post #2 of 8 Old 02-13-2011, 08:31 AM
majorleaguebass's Avatar
yea they sell a switchless kit on ebay...type in pioneer 3200 bypass and it will come up...i just ordered one for my 3200bt and it was 10$...no switches to flip, automatic
2015 F350 Platinum
TK Performance
4" Rancho w/ Fox Shocks
24" American Force Independence
37" Toyo Mt
Custom Bullydog Cheats
5" Flo-Pro
H&S Intercooler Upgraded Pipe
majorleaguebass is offline
post #3 of 8 Old 02-13-2011, 11:17 AM Thread Starter
knostroke's Avatar
WOW thanks i knew there had to be a way. Do you know if you just hook up that green wire to that relay?? I really dont want to take apart my dashAGAIN to hook it up to the back of the head unit
post #4 of 8 Old 02-13-2011, 11:27 AM
no, it hooks up to 3 wires back there, so you would have to take it apart...
2015 F350 Platinum
TK Performance
37" Toyo Mt
5" Flo-Pro
post #5 of 8 Old 02-13-2011, 11:34 AM
oh yeah, dont get the ones in the little crack baggie...lol. get the one that shows a pioneer box behind it...other one has some kinda switch, then you have to figure out where to stick it, plus its ugly
2015 F350 Platinum
TK Performance
37" Toyo Mt
5" Flo-Pro
post #6 of 8 Old 02-13-2011, 11:54 AM
i know with my pioneer it was a matter of just moving one wire. there is a few pioneer forums i believe and they should have step by steps.
75' forty is offline
post #7 of 8 Old 02-16-2011, 07:05 AM
06BigRedPowerstroke's Avatar
Quoted: 5 Post(s)
It works off of a ground but you do not want to have it on a constant ground. Theres a couple different ways of doing it you can run a toggle switch to ground. The way I did it was use my upfitter switch to power a relay which grounded the stereo wire. Or you can install the relay and use the preamp power wire from the stereo to activate the relay that way its bypassed every time you turn it on.
06 F-250 Fx4
4.5inch Icon Stage 1
37/12.50/20 BFG AT
06BigRedPowerstroke is offline
post #8 of 8 Old 02-16-2011, 07:22 AM
Quoted: 3 Post(s)
I just gave the best buy guy installing it a 20 and wa-laa done.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
